Honda K20A supplement
customDIY
4,000 RPM
Brand New Honda K20A S90 Racing Throttle Body for sale
70 MM Throttle
Vent , more than 100 pcs of ready stock . Export quality
Intro:-
* The throttle body unit was made from Precision CNC machine & material are
Aluminium AL6061 - T6 Billet
* The throttle shaft & Blade was made from AL7075 can stand for more higher
boost
* We been tested at High Boost 3 Bar & Normal Boost 2.5 Bar Engine
* Throttle body was done by Hard anodized coating to increased Durability
* T/B unit material can stand up to 350 c
* Both side of the shaft was comprise of Branded Ball Bearing to put out the
best respond
* Plug & Play easy install
* Stylish design
1 Year warranty of our Throttle Shaft , Blade & Ball Bearing .
Nation wide courier service
Dealer wanted
For more further infomation pls call
60177791517 Vincent
Mail add : [email protected]
Quality is everything , Plug & Play with stock sensor . High Grade Material will Contains Certificate we promise
Buy 1 OTB get 1 Billet oil Cap (F.O.C) , limited 25 pcs only ! While stock last
Bump: Promotion ! Promotion !
