Hi all ppl & sifuu's :wavey:. I know that a similar thread was created sometime in 2005, but the TS didn't update it after that. Im just 'passionately curious' (borrow from Einstein words
) about facts.
The list below was written by mahBLACKaccord from usa in www.accordracing.com
Engine Codes / Size / Type / Vehicle & Power Ratings
EW4 1.4L & 1.5L SOHC PGM-Fi '84-'87 Civic 60-92hp
D15B 1.5L SOHC non-VTEC '88-'95 Civic's 62-102hp
D16A1 1.6 L DOHC 86-89 Integra 86/87 113hp 88/89 118hp
D16A6 1.6L SOHC 88-91 Civic Si/ CRX Si 108hp
ZC JDM equivalent of D16A1 130ps
D16Z6 1.6L SOHC VTEC 92-95 Civic EX/Si 125hp
D16Y5 1.6L SOHC VTEC-E 96-00 Civic HX 115hp
D16Y7 1.6L SOHC non-VTEC 96+ Civic CX/DX/LX 106hp
D16Y8 1.6L SOHC VTEC 96+ Civic EX 127hp
B16A 1.6L JDM DOHC VTEC 89-91 Civic Si-R I/CRX Si-R, Integra RSi/XSi 160ps
B16A2/3 1.6L USDM DOHC VTEC 93-97 DelSol VTEC/99-00 Civic Si 160hp
B16A 1.6L JDM DOHC VTEC 92-95 Civic Si-R II/ 92-97 CRX DelSol SiR 170ps
B16B 1.6L JDM DOHC VTEC 98+ Civic Type R 185ps
D17A2 1.7L SOHC VTEC-E 01 Civic EX 127hp
D17A1 1.7L SOHC non-VTEC '01+ Civic DX/LX 115hp
B17A1 1.7L USDM DOHC VTEC 92-93 Integra GS-R 160hp
B18A1 1.8L USDM DOHC non-VTEC 90-93 Integra RS/LS/GS 90-91: 130hp / 92-93: 140hp
B18B1 1.8L USDM DOHC non-VTEC 94-01 Integra RS/LS/GS 140hp
B18C 1.8L JDM DOHC VTEC 94+ Integra SiR-G 180ps
B18C1 1.8L USDM DOHC VTEC 94+ Integra GS-R 170hp
B18C5 1.8L USDM DOHC VTEC 97+ Integra Type R 195hp
B18C6/7 1.8L JDM DOHC VTEC 96+ Integra Type R 200ps
B20A5 2.0L DOHC non-VTEC 87-91 Prelude 2.0Si 135hp
B20B 2.0L DOHC non-VTEC 96-98 CR-V 126hp
B20Z 2.0L DOHC non-VTEC 99-01 CR-V 143hp
B21A1 2.1L DOHC non-VTEC 90-91 Prelude Si 145hp
K24A4 - 2.4L DOHC i-VTEC - 2003+ Accord
K24A4 - 2.4L SOHC i-VTEC - 2004+ Acura TSX, Honda Element,2004+ Accord (JDM)
K20A3 2.0L DOHC i-VTEC '02+ RSX 02+ Civic Si 160hp
K20A2 2.0L DOHC i-VTEC 02+ RSX Type S 02+ Civic TypeR 200hp
K20A 2.0L JDM DOHC i-VTEC '02+ Integra Type R 220ps
F20A1 2.0L JDM DOHC non-VTEC 90-93 Accord Si 155hp
F20B 2.0L JDM DOHC VTEC 90-93 Accord Si-R 190ps
F20C1 2.0L DOHC VTEC '00+ S2000 250ps/240hp
F22A1 2.2L USDM non-VTEC 92-96 Prelude S 90-93 Accord LX/EX 130hp-135hp
F22B 2.2L USDM SOHC VTEC 94-97 Accord EX/97 2.2CL 145hp
F23A5 2.3L USDM SOHC 98+ Accord DX 135hp
F23A1 2.3L USDM SOHC VTEC 98+ Accord EX & LX/98-99 2.3CL 150hp
F23A4 2.3L USDM SOHC ULEV VTEC 98+ Accord EX & LX 148hp
H22A1 2.2L USDM DOHC VTEC 92-96 Prelude VTEC 190hp
H22A4 2.2L DOHC VTEC 97-01 Prelude VTEC/SH 97-98: 195hp 99-01: 200hp
H22A 2.2L JDM DOHC VTEC 92+ Prelude Type-S, 97+ Prelude SiRS Spec 220ps
H23A1 2.3L USDM DOHC non-VTEC Prelude Si 160hp
G25A1 2.5L USDM SOHC non-VTEC 96-98 2.5TL 176hp
J25A 2.5L JDM SOHC VTEC V6 JDM Honda Aspire/Sabre 200ps
C27?? 2.7L USDM SOHC non-VTEC V6 86-89 Legend 150-160hp NEED HELP ON THIS
C27?? 2.7L USDM SOHC non-VTEC V6 95-97 Accord V6 170HP NEED HELP ON THIS
C30A(?) 3.0L DOHC VTEC V6 91-96 NSX/NSX-T 270hp NEED HELP ON THIS
J30A1 3.0L USDM SOHC VTEC V6 98-02 Accord V6/97-99 3.2CL 200hp
C32A6 3.2L USDM SOHC non-VTEC V6 91-95 Legend Sdn, 91-92 Legend Cpe 96-98 3.2TL 200hp
C32A5 3.2L USDM SOHC non-VTEC V6 94-95 Legend GS Sdn, 93-95 Legend Cpe 230hp
C32A? 3.2L DOHC VTEC- V6 97+ NSX/NSX-T 290hp NEED HELP ON THIS
J30A4 - 3.0L SOHC VTEC V6 - 2003+ Accord
J30A - 3.0L i-VTEC - 2003+ Honda Inspire (JDM)
J32A1 3.2L USDM SOHC VTEC V6 98+ 3.2TL/3.2CL 225hp
J32A2 3.2L USDM SOHC VTEC V6 00+ 3.2CL Type-S, 01 3.2TL Type-S 260hp
J32A3 Acura TL 2004+ 3.2L V6 (201 kW) 270 HP SAE @ 6,200 rpm; 238 ft lb , 323 Nm @ 5,000 rpm
C35A2 3.5L USDM SOHC non-VTEC V6 3.5RL 215-225hp
J35A1 3.5L USDM SOHC VTEC V6 98+ Odyessy 210hp
J35A3 3.5L USDM SOHC VTEC V6 Acura MDX 240hp
To mods, i'll remove this thread if it shoudnt be here. To all its not complete. yet.
Bump: Below is a listing of Generation 4 Honda Accord and Generation 3 Honda Prelude F22 Type engines.
F22A1: 1990-1993 Accord, 2.2 liter (2156 cm³), MPFI fuel system, 125 hp (93 kW) @ 5200 rpm, 137 lbf·ft (186 N·m) @ 4000 rpm, 8.8:1 compression, oil pressure 50 psi (340 kPa) @ 3000 rpm.
F22A4: 1990-1991 Accord, 2.2 liter (2156 cm³), MPFI fuel system, 130 hp (97 kW) @ 5200 rpm, 142 lbf·ft (193 N·m) @ 4000 rpm, 8.8:1 compression, oil pressure 50 psi (340 kPa) @ 3000 rpm.
F22A6 1990-1993 Accord, 2.2 liter (2156 cm³), MPFI fuel system, 140 hp (104 kW) @ 5600 rpm, 142 lbf·ft (193 N·m) @ 4500 rpm, 8.8:1 compression, oil pressure 50 psi (340 kPa) @ 3000 rpm.
The following list of F22B Engines are [VTEC] and [NON-VTEC] SOHC Engines found in the 1994-1997 Honda Accord, 1995-1997 Honda Odyssey, and 1997 Acura CL.
F22B1 1994-1997 VTEC Accord EX, 1997 CL, 2.2 liter (2156 cm³), MPFI fuel system, 145 hp (108 kW) @ 5500 rpm, 147 lbf·ft (199 N·m) @ 4500 rpm, 8.8:1 compression, oil pressure 50 psi (340 kPa) @ 3000 rpm.
F22B2 1994-1997 Non-VTEC Accord LX, DX, SE, 2.2 liter (2156 cm³), MPFI fuel system, 130 hp (97 kW) @ 5300 rpm, 139 lbf·ft (188 N·m) @ 4200 rpm, 8.8:1 compression, oil pressure 50 psi (340 kPa) @ 3000 rpm.
F22Z2 1996-1998 VTEC Accord (Euro), 2.2 liter (2156 cm³), MPFI fuel system, 150 hp @ 5500 rpm, ??lbf·ft (??N·m) @ 4500 rpm, 9.3:1 compression. NEED HELP ON THIS
F22B6 1995-1997 VTEC Odyssey, 2.2 liter (2156 cm³), MPFI fuel system, 145 hp (108 kW) @ 5500 rpm, 147 lbf·ft (199 N·m) @ 4500 rpm, 8.8:1 compression, oil pressure 50 psi (340 kPa) @ 3000 rpm.
) about facts. The list below was written by mahBLACKaccord from usa in www.accordracing.com
