Honda Diet Program (Lighten Your Car)
hattech-v
for anyone planning a diet program for ur honda (to reduce weight for ur car), i got a list for parts weight like the following. i did measure the weight myself using 30kg timbang pasar malam... :P. All parts sourced by AVANTECH. :)
1.B16B head w/o cams - 21kg
2.EK9 Rear Bonet - 17KG
3.TE37 Ori 15" - 4.5kg
4.Hoosier Full Slick 15" - 9kg
5.EK Standard Seat - 16kg
6.EK9 Flywheel - 6.8kg
7.Head Cover - 2.5kg
8.EK4 Steering with Airbag - 3.7kg
9.ITR Steering w/o Airbag - 2.3kg
10.ITR Strut Bar - 1.5kg
11.EK 99 Spec Front Bonet - 13.8kg
12.Type R Distributor - 2kg
13.Type R Cams - 4.5kg
14.EK4 Rear Disc (Per side) - 18.5kg
15.EK4 Disc (Disc Only) - 3kg
16.B18CR Crank - 16kg
17.99 Spec EK Fender - 2kg
18.EK4 Door trim (per side) - 2.5kg
19.Power window motor - 1.2kg
20.EK4 Rear Windscreen with Wiper - 8.5kg (motor only 2kg)
21.B16B OEM Extractor - 12.5kg
22.Type R Block Brace - 2.6kg
23.99 Spec Taiwan Bonet - 16kg (extra 2kg fr original)
24.Aircond Compressor - 5.6kg
25.Starter - 3.2kg
Thats all for the moment. i'll update if done wif another parts.
any contribution here also welcome.
start the diet program now n gain the better PTW (same like BMI)... hehe
mrbear said:
piston weight?
That one varies ah.. that's why those kind of weights doesn't matter.. usually balancing your engine include balancing the piston weights, so canai here and there... no specific weight already. :P
hattech,
How bout spoiler? EK9 / DC2R / Mugen etc..
If we use CF parts like hood / spoiler etc, how much difference there can make in terms of dieting the car
Item to remove when racing:
Remove Spare Tire 9 kg
Remove Jack 2.5 kg
Remove Floor Mats 4.5 kg
Remove Passenger Seat 13.5 kg
Remove Rear Seats 4.5 kg
Remove Muffler 4.5 kg
Drain Washer Fluid 0.4 kg
Remove Cruise Control 3.6 kg
Remove Speakers 3.6 kg
Remove Stereo 1.8 kg
waahh...spare tire 9kg...no wonder my car berat....after this i want take out spare tire...then less 9kg...but if pancit i call avantech to borrow Hoosier full slick tire n TE37....hahahaha
Remove Jack 2.5 kg
The above reduced 47.9kgs
Items that can reduce weight when changed to these (ori weight - aftermarket weight) :
CF bonnet : 16-7 = 9kgs
3-spoke sports steering wheel : 3-1 = 2kgs
Full bucket seat : 25-14 = 11kgs
4-1 jasma header : 10-6 = 4kgs
Lightweight flywheel : 7-4 = 3kgs
CF side mirror : 1.5x2 - 0.5x2 = 2kgs
Lightweight underdrive pulley : 1.5-0.5 = 1kg
Remove Rear interior side panels (EK hatchback) : 3kgx2 = 6kgs
Remove centre console box : 2kgs
Lightweight coilovers : 5x4 - 3.5x4 = 6kgs
The above reduced : 46kgs
But if you think u just want a drag machine and just wanna focus on going straight and not turning :_: , then u hv successfully reduced about 94kgs.
But since honda's are not used for only going straight, then i'd suggest putting in these :
Rear strut bar : 1.5kgs
Fender bars : 0.5kgx2 = 1kg
Room bar : 3kgs
Total to add : 5.5kgs
Nett reduction = 88.5kgs
Moral of the story : Don just go straight :_:
You guys forgot the power steering assembly.. some weight trim off that too.. still a streetable setup.. though parking becomes quite some work.
