High End 6.5" comp speaker VDOdayton HPC1700
ICE -In Car Entertainment
stephen_07
Specification
Max power 300 watts
RMS (nominal) power 150 watts
sensitivity 91 dB/1W/m
nominal impedence 4 ohm
frequency response 45Hz - 20kHz
Made in Denmark
Materials
woofer cone Nomex/Kevlar/Glassfibre Composite
basket material cast aluminium
woofer magnet strontium ferrite
aluminium voice coil
SBR rubber surround
gold-plated connectors
soft dome tweeter diaphragm
Dimension and Weight
woofer size 165mm
mounting diameter woofer 145mm
mounting depth 82mm
tweeter size 25mm
mounting diameter tweeter 42.5mm
magnet size (diameter) 95mm
magnet weight 0.53kg
Other
corssover frequency 3800Hz/12 dB
adjustable 0dB, -3dB, -6dB tweeter gain
interestested pls pm or sms 016-7707857
