hid question
skyline2m
is there any hid that:
high beam = hid
low beam = normal yellow lamp?
usually hid that i saw at accessories shop sell
high beam normal yellow
low beam hid
nope....
maybe you can make an extra projector fog lamp, and link the wiring to your high beam.
So, you will get halogen + HID high beam.
its done like that because of your high beam. if you put hi-HID, then every time you 'flash' someone, the HID will switch on, and because its on for only 1 second or so... it will wear out the ballast.
if you really want to do it, just ask you friendly accessory shop to reverse your headlight wiring ...
i mean for H4 bulb with
high beam = hid
mostly hid that i saw at the shop/internet is the inverse of what i want
the reason i want this become like that is because of afraid of roadblock
means that usually we will use low beam when driving and only high beam when in a very dark place with no roadside lamp
therefore by using high beam as hid will suitable for me and also to prevent summon
if using low beam as hid sure will get summon or when we saw road block then we high beam (normal yellow) sure the police will ask y is the reason that we use high beam suddenly right
anyone can help me??
aiyo, u ppl long time no go acc shop?? i use H4 HID for my satria, high beam is H1 halogen bulb, low beam use hid. korea made, rm 280 oni. wen u turn on light is use low beam hid and wen u switch high beam, is oni use normal H1 halogen, no hid.
so can easy switch we u c `MATA` (polis)!!!
but if u switch 2 high beam, will also glare the police and they will ask u 2 stop n ask y u switch 2 high beam even there is roadside lamp n also got car from the opposite direction
for normal h4 bulb, u can c 1 `filamen` is face up, ` is face straight. for h1 bulb is face staight. tats y even u high beam ur h1 bulb , is oni low beam effect. u gt wat i wan to say?
hope tis can help u.
yes i understand, thanks for the information that i really want. u mean that even if u high beam for H1, it only the same effect with H4 low beam. Im a potential buyer for hid. i plan 2 buy it but afraid that if i high beam (H1), the effect is the same with high beam for H4 so sure the police will question me y so bright also want to use high beam
skyline2m, there's another easy way. Just switch the low beam & high beam pin connecting from the HID kit to the original bulb socket. This will change the low beam to Halogen and high beam to HID.
Thanks for your idea. So u mean if my ori bulb is H4, i can install H1 bulb for high beam use? I installed a set of HID low beam only in my car before but already took it out. Planning to install it again.
I just install a HID from Jojo.. u can find him over the marketplace..
For me i install the HID at fog lamp myvi, headlight i leave it normal bulb.
HID got different Kelvin color, If you install less than 5K and you on it all the time even when u meet road block, i think you still be safe as below 5K will looks bit yellowish..
if you install for your better driving, install less than 5K
because you will find difficulty to see the road when raining if more than 5K(higher K, the whiter and the bluish color).
I can tell this because i on only my HID(8K) during rain, i see nothing, thank goodness my headlight still yellowish type..can see the road much better..
Hope my sharing helps..
i guess this will be the thread for you guys to share about hid
just 1 thing i ever saw ppl install h4 hid (if not mistaken) with high beam = hid and low beam = normal yellow
his low beam normal yellow almost like the same as normal h4 yellow bulb
My cousin installed that in Persona, low beam are normal light and high beam are 8K HID..
For my opinion i need to keep low beam and high beam the yellow light just for my safety reason,
as for log light not far the light projected so i install it for show off only.. you know la.. kids mah..
HAHAHA..
Sooner ill consider install HID on headlight as well but not more than 5K..
I bet you dont want to know because my cousin installed it very expensive..
H4..low beam normal lighting and high beam 8K HID is very common HID in market..
Look for Jojo9984(seller) in marketplace.. I believe he can help you..
hello all sifu2 here,
It is possible to DIY the HID? I mean that we buy the part separetely such as ballast,bulb n etc...?
If possible,how the wiring diagram looks like?
