the other way is hide the ballast inside the headlamp. buy the slim ballast, and try to fix it inside the headlamp. so, it looks more original.and JPJ can't find the ballast. the thing that they can do is ask you to go for inspection. at that time, change it to halogen bulb..sure can pass..but if happen that they ask you to go for inspection, you need to spend some time to convert it to stock and go for inspection. The downside is they might check for other thing like tinted etc..for my High beam, i was thinking to put the ballast inside the headlamp..look original..no messy wire..
