Hi-cam Questions
Legend_MaRS
erm......everytime when i read these car modification magazine ...
these car sure mod HI-CAM ....
HI-CAM for racing use !! erm......tis 1 i know ...
but~~
if i install a hi-cam , what else i need to mod together wif hi-cam to make it balance till perfect leh ??
hi-speed pulley ? ECU setting ? dyno test & setting ?
what kinds engine r suitable to mod HI-cam ? All ?
any negatif effect ? any positif effect ?
hi-cam can higer the engine rev ?normally can higher how many RPM ?
erm.......what my questions all there ....waiting ZTH sifu to answer me ...
NEWBIE ~~~ need sifu teach ~~~ B)
usually DOHC engines change their camshafts
must go with adj cam pulleys
this is to adjust and tune the cams
but also need piggybacking cos fuel and stuff changed settings.
For HI-Cams you will need
HI-Cam Pulleys
HI-Valve Springs
HI-Ported Cylinder Head
HI-More Compression
HI-ECU
and of course a HI-Driver.. :lol:
Yes Esky, not forgetting that. And if your idle gets really bad you'll also need an understanding HI-GF :lol:
There's almost no such things as 'perfect' unless u change your whole car.... hahaha. Basically a lotta things can be done to support the high cam... unfortunately, modifying cars is like that... u mod 1 thing, you'll need to mod 10 others to support.
High cams also got a lotta different profiles. Depends on what are the cam profiles also.
Assuming u're just upgrading to regrinded cams... then the few most important things you'll need to do is to get adjustable campulleys, fuel regulator and a piggy back to adjust your fuel (of course with proper tuning as well lar)....
Some aftermarket cams like those done by Toda, Crower, etc etc... requires you to change the valves and valve springs along with the high cams...
Installing high cams doesn't mean you get higher revs... your revs will still remail the same... chances are, your rev cut will still be there (if any... unless u take it out)...you'll only be shifting your powerband to a higher rev... where you will be most of the time during racing. This of course would mean that your lower end powerband will decrease... leaving your lower revs to feel more sluggish than usual. Too high a cam and your city driving will be very disastrous... idling will be difficult, and your car's power simply won't kick in at lower RPMs.
Hope this helps... just a rough idea lar.
Esky,
Don't understand your question? :blink: Isn't the VTEC and iVTEC implementation the specific answer to your question?
juz wanna ask simple question..if car oledi change ekzos system, plug n plug cable, ecu, air filter n intercooler n engine din mods.....n direct put in high cam..can? :)
ya evo 3 ma....sure got turbo...who say turbo cars cant put in high cam? o saw lots of posts selling hks high cam for evo engine ar????? :(
CAn put... why kenot put... but depends on what cams you put in. If its just regrinded cams... than you'll probably just need a piggy back to control the fueling.
If you use evo aftermarket cams, like HKS, Toda.. etc etc.. you'll need to get the valves and valve springs together with your cams... then also a piggy back to adjust the fueling.
Going to be quite costly... so why not just upgrade turbine instead? Look for a 20G turbine lar... shouldn't cost more than the aftermarket cams.
