need help...
yesterday when crank ignition, it seem no fuel supply...so i take out the fuel pump and crank again, the fuel pump motor not functioning, so i test it on my friend car, when crank it...the fuel pump motor function....i suspect is the fuel pump relay problem....any sifu know how to check if the reply having problem?? where is the reply locate at BT with BT wiring in SEG body?....beside the relay , any other posibility that you can hear the crank sound but no fuel supply?....need urgent help....car still in my office basement......
