help needed on elec X-over
Gti
to all sifus out there...can u all recommend me a good 2\3 way elec x-over?
my budget is strictly below rm200....
or are there anyone selling any good used elec x-over here in zth?
i am very very noob in ice...i only know how to listen
now my alphasonic 2\3 way elec x-over already kong...
so need to find replacement...but no more budget already...
hope all sifu can give good advice...
thanx
sifu....i dun think i have any passive cross over la...
my setup very simple only...
i 2 channel amp for my woofer
and i 4 channel amp for my components set
and i don't have a pre-amp
that's y my X-over is very important lor....
hope sifu can help...
I'm not sifu :D my setup almost same like yours... 1 x 4ch amp / 1 x 2ch amp / but my rear is comp set with crossover.... and i have a preamp... now wanna add a electronic x-over... any brand to recommend ? Mohawk MK 3I ok or not ? Do i still need to use back my current passive x-over after installing the E x-over ?
Having both PreAmp + Acitve XO isn't usually the recommended way. I have my preamp is meant ONLY for the SUB VOLUME.
I think there are people selling good XO's (2nd hand) in ZTH sell/buy section and gr8tuners.net
Check there out.
Mohawk aaa.... eeerrrrr....
:wink:
Viperize said:
Gti , do u use preamp for your setup ?
When u use Active E-Xover u remove all passive ?
pls share with us the rest of your system before we can advise you....
Pioneer 4550
Mohawk 5S Preamp
Oxygen 4 channels amp (for front & rear comp set)
American Autocraft 2 channels amp (for 10"sub)
Boschmann 6" speaker (front)
Lanzar Tweeter (front)
Oxygen 6" & Tweeter (rear with X-over)
Did i miss out anything ? Wanna add another Mohawk MX 3I 3ways Electronic X-over.
Please advise.... and yeah... from changing my previous kennon preamp to mohawk i get some improvement
Viperize said:
Pioneer 4550
Mohawk 5S Preamp
If you are going to use the XO then the preamp can go (unlike me using the preamp SOLELY for the SUB VOLUME). But I don't know about specs as I'm NO where good in calculations :tongue:
Determine good or not the quality, surf around and see if any related comments to the product :wink:
Viperize said:
Pioneer 4550
Mohawk 5S Preamp
guess a 3way crossover wont hurt, just connect from hu to xover to both amps, using front, rear and sub mode. u will need passives for front & rear comp sets.
I see... u mean HU to XO straight ? Dun need tru Pre-amp ?
Or continue using the pre-amp .... HU - Preamp - XO - Amp - Speaker ??
Any big different between 2 setup ?
How many filters you want to go to?
ICE is not water, the less filters the better well depends on how you see it :wink:
