Two days ago,i change SQV hose,sard fuel regulator upside hose,hose from HKS EVC5 solenoid to wastegate to blue samco silicone hose.After that,i drive my car n really suck,no power at pick up,step my pedal habis around 3000rpm at 4th gear and the car wont go,it stall a little while and like something stuck...reset the EVC oso no use,oso got turbo whistle sound when u release the pedal.Oso when pedal,the evc show the boost reading from negative to positive will stuck at 0 awhile...Later i change back all the samco hose back to previous hose oso same problem,i didnt realize changing those hose can effect the car so trouble,anyone have the same experince b4?PLEASE HELP....
I also change new hks filter element when change the samco hose,the old 1 is already very dirty and is 2layer wet type filter element,i change to new 3layer dry type,is tis cause the problem?I use ori ecu btw...
