help me pls pls pls!!!!!
93na
hai every wan i need help!!!!! i m drivin a 4g93 engine that was bot before but now i m running na!!! so the ecu was rechip to suit the bot since now it na the fuel and performance is so bad!!!! i when to a few workshop all of them say the only way is use emanage coming up to 2k!!!!! wat can i do if i dont wan to used emanage!!! can i just swap and fit a normal 4g93 ecu in!!!!! i dont know where and wat type of rechip was done!!!!! but using 97 ecu system!!!
pls pls i need help going broke pumping fuel!!!!!!! ha ha ha!!!!
thanks every wan!!!:listen::listen::wavey:
no stok ecu??..erm..put back stok chip??...tune back ur engine??..
go d place whr u did d mods la...find stok ecu..ke??
ya bro thinkng bot it!!! but by mid next year i wan to fix highcams on my ride so i m thinking should i just install emanage!!!!
btw do have a stock ecu????????????
u rechip it so it can read positive boost pressure... but it is still not fine tuned... it is advisible to get emanage to fine tune it...
