help me on TEIN adjustable
QiW said:
why la so susah ?? just take a drive there lorrr .. if not then just go N1 in sunway lorr .. they sure have one since they are the authorised distributor for TEIN over here ..
all only $$$ .. hehehehe
confirm at N1 have that thing???
you can knock the sleeve ring lightly using blunt object to loose it bro....
it will loose.... and then set the preferred height... when everything done... knock again la... but make sure using blunt object cos sharp edges may crack the rings.
knock it slowly... and use WD40 to aid the process...
most of the time the rings are jammed due to weather, sand and corrosion. that time.. a ring wrench won't be able to help ya..
