Help! Evo 3 throttle body on perdana!
I just bought an evo 3 throttle body. The seller said that it would fit into wira 1.6 and same goes to Perdana sei.
Perdana sei is my car. Currently im using jasma 72mm throttle body which in the end have its sensor broken and i tried installing evo 3 throttle body but the timing/rpm went bursting everytime i start the car, and i'll quickly turn off the engine. And now i've cabut it back.
so... CAN REALLY EVO 3 TROTTLE BODY FITS PERDANA SEI STANDARD ENGINE?
if can, do i need some adjustment for it to work properly?
When i compare perdana sei throttle body and evo 3, it looks completely the same!
http://www.mudah.my/Throttle+body+EVO+3+dan+PERDANA-21099940.htm
Only perdana v6 using those stepper motor (idle air control valve).
Perdana SEI should flat straights 6pins type...!
Ur perdana is sohc or v6?
