::HELP Engine dies when clutch is pressed!::
Lolo Rider
I drive a Toyota KE70.My car starts ok but then the rpm drops below 1 and the car shakes badly then eventually dies.
This also happens on the road whether the car is in gear or free gear.What could be the problem?
something to do with your throttle body i guess. had the same issue with my wira back then. replaced with a new TB, problem solved.
ke70??...stock 4k engine??
no tb..just carbie:hmmmm:...so, check ur carbie...whether its has problem...4 the 1st step
mmm...i hv such experience..the problem is clutch bearing jam
changed it...then problem solve:burnout:
