[HELP]Electrical burning smell at steering wheel, and headlight can't be turn off.
cheeriochin
guys, need help.
My car is 9gen altis, 2003,
I was driving for almost 2 hr, then smell some short circuit burning smell inside the cabin.
park the car at the road side , then i realized headlight cannot be turned off.
i quickly disconnect the battery to prevent further damage to my car.
it didnt gv any sign prior to the burning smell. and the smell came from the steering wheel itself, on top of the airbag area
anyone can guide me here?
Re: [HELP]Electrical burning smell at steering wheel, and headlight can't be turn off
Erm where r u now?
oh..me now in tapah..
just now i connected the battery, prob persist..
any 1 can tell me wats happening here?
tq
is there any other wires connected to your batt terminals?
dude,
same thing happen to me before with my putra. try the fuse box.
The fuse for the light would have melted........ if it is..... be very carefull when pulling it out....i burnt my finger when i tried to pull it out.
for 9 gen Altis, there are two fuse boxes: One at the engine bay and another one behind the glove box.
there is a crocodile clip to take out the fuses in the engine bay, in white transparent color. Use that will be more convenient when you check for any fuse that may burned.
thanks, i will try that
wired short circuit but the fuse didnt break..
i wonder why
now i am driving out for diagnostic chk
hope everything is ok
thanks ya
can't believe the car with this price will hv this problem
If find the problem, let us know also..... :)
[snapback]46645352[/snapback]​
problem found, this signal stalk got fried , problem fixed after replace the signal stalk
my car need to be tow to workshop
everytime i start my car, can see smoke coming out from the signal stalk
LESSON TO LEARN HERE
1. If sense burning smell, quickly stop at the roadside when it's safe to do so.
2. Quickly turn off engine, disconnect the car battery.
3. the car need to be towed, do not attempt to drive it yourself.
thanks for your advice guys, tq
Hi, I have the similar problem.
May I know where you went to fix the problem? Toyota SC?
check the wiring around that switch, happen to me last time, turns out that the wire melt into each other, causing the current overflow and smoked the switches.
