To all evo 7 sifus , is there any problem to install a bov on a evo7? ive heard tht it will make the engine lag or something like tht.. anyone experienced this b4 kindly feedback me pls.. thank u very much!
saiyuke,
What you can do is put your car into 4th/5th gear, drive it up to around 4500-5500 rpm and then try to modulate your throttle by gently lifting and reapplying pressure on the accelerator.
If you are having issues with the SSQV, your throttle inputs will be juddery rather than smooth. There really is nothing you can do if this is the case, it's just that the EVO doesn't like atmospheric valves. Don't go and adjust the SSQV (if yours comes with the adjustment screw) as this will only increase compressor surge, not a good thing with the IX's turbo. If it's smooth, then you're probably fine.
Did your car come with the SSQV or did you swap out the stock valve?
My advise would be item 1. Cheapest and best wayQuick and simple:
MAF + VTA BOV = Engine Flutter or Stall (only problems with evo7, havent heard such issues on e8/9)
Possible solutions:
1. use re-circulate BOV like Greddy RS, SQV with recirc kit (hard to find) or ori BOV.
2. install HKS EIDS which cost around RM400+
3. change to a MAP (intake manifold pressure) ECU instead of MAF
4. don't use your aircond
I personally tested option 1, 2 and 4 and it works. But i am sticking with EIDS but removing soon after replacing my ECU. Let me know if anyone is interested in my EIDS.
Cheers!
