Heat resistant spray
gti88
1,500 RPM
Guys,
Looking for heat resistant spray, want to try a little DIY project as I've never
tried it before .. haha .. I want it in RED, tried looking in ACE hardware,
both Mid V and Ikano but to no avail, any ideas where can I get them ?
Thanks in advance. Cheers to all ! ;)
any hardware shop...
can stand heat up to 800c.. normally used by motorbiker..
or u can try to ask motorbike shop..
it looks like normal can..
the name tells everything, dude.. HIGH TEMPERATURE SPRAY.. so where to spray? u think about it la..
coz motorbiker like to spray on their engine cover..
but most hi temp spray doesnt come in red color...its either black or silver... what most people would do is spray the first coating with hi temp silver color, then second coat would be the desired color....then lastly, cover it with clear coat to make it shiny....
just make sure the surface is totally clean and dry.... i assume u would want to spray ur caliper...however, if u want cheper stufs, use oil based paint...rm5 per smallest can.... then use clear coating spray... should give u the same result...
