headlamp
eskbtp
hi there. i got the problem here. after rain or during rain, my headlight very poor as if i switch off my light.i cannot see road surface.i already changed to vision plus.but still not work. so i plan to replace my reflector.so any one know where the shop which sell the reflector(diamond type) in kl??i already bought headlight from chop shop but not work too.
one more question.my fuse connect to relay usually melt. why?i use fogged ligt. izzit due to my fogged light??
did u tinted ur wind screen?
where did u get ur fog light from? the fuse can support or not?? wiring correct??
hi ksgoh..my windscreen is ori.no add-tinted. i am using yellow foglite rm35 one.can get fr any shop.
the shop ppl said all fuse is same.but one shop said that i should use kw relay cable which more pricey due to it can work for hotter bulb. is that right? now i am using rm38 relay cable only.
wiring i think ok.but b4 i installed fog lite, my lamp already not bright. i had tried to adjust the headlight but no improve.
is that good if i try to use bulb which labled 55/60 to 100/130.is that better choice for brighter ? anything need to modify?
