head Mivec lifter sound
Blue>8756
Hi guys, don't know wether this topic has been discussed before or not.. try to search but couldn't find it..
need help on my mivec head, has been used head mivec in 2 years time on my gsr, now got lifter sound like 'tek tek tek' like gsr teppet sounds, i realize that sound rise up after i late to change an engine oil, already done at 5+++km then baru tukar.. huhu
foreman already adjust the teppet but still got sound, so how do i solve it? foreman said i must change the lifters, but some says the lifter can be serviced like gsr teppet, the sounds annoyed me.. :bawling: and also does the lifter sounds effect on engine performance? pls help me on this.. thanks a lot
My opinion is that service tappet will only able to reduce the sound, but it will come back again . Suggest you to change another brand new tappet set for ur engine. Service your engine according to schedule , and do not use lean engine oil such as 5w40 or 10w40.
shell oils alot of immitations in the market, last time i used shell semi syn, the tappet sound was loud.....switched to motul then ok.
