hd & gtti piston, need info..
openg
hi .... i just find out that gtti n hd have the same size of piston....76 mm...
so anyone out there had try to install Gtti piston inside hd block for turbo charge...
does anyone out there compare the piston..
i wanna find out ... does the shaft n pin Gtti piston is at the same location as the hd piston...
the lenght from the top piston to the shaft hole.?..
the diameter of the shaft hole ?
any one out there that can share the info..plsss.....:Not_Impressed:
how to put in?imho,the size maybe the same.but the compression ratio is different.the gtti is turbocharged hence it has a low compression piston.whereas the hd is n/a hence it has a high compression piston.
if im not mistaken it can be done...but im not sure bout da process and calculation though...maybe someone else can answer dat fer u?
ya bean.. na have high comp piston n turbo has low comp piston... but that the point off using it... if wanna turbocharger the hd engine by hoping the piston can last longer n can boost a bit high... the diameter of the piston is the same so shouldn't be a problem accept for the shaft piston position...that what i'm trying to find out.....lol....
hey..come to my workshop la..wat block u wanna use fer the piston..
hurmmm..mine is kanciL..
850 c.c ..using the same block im using 2E turbo piston..can be done one la..bigger than gtti..
if u are using 1000cc..can use 4E turbo piston...damn fast!!!!!!!
anyone have some info on thid HD engine... mounting wise.... bores troke and etc... any web site which i can compare to my kembara HC-EJ .? cause as far as im concern its almost the same...any sifu can tell me bout this. URGENT HELP
