handbrake sign blinking
scarletdiva
hi,
Do you guys experience any handbrake signal light keeps on blinking continously?......what is the problem actually?
scarletdiva
rear brake pads will cost u approx 250++ for OEM toyota........if u want tanabe ones, i can hook u up for it....
when does the handbrake side blinking occurs....when the handbrake is up ?
sometimes it is just a simple connectors problem because of the heat generated underneath the handbrake so the connectors tends to loosen up after u run the car for some times....
mine's handbrake light sometimes also will blink during i press the brake hard...what is the problem ? i check my brake fluid still ok...still half of it...this thing occur after i change my brake pad...isit related to it ?
