Haltech Platinum Sprint 500
D`s Garage
7,000 RPM
Engine Suitability:
• 1 to 8 Cylinder engines
• Normally Aspirated or forced induction
• Load sensing by throttle position or manifold pressure (MAP)
• Sequential, semi-sequential, batch or multi-point injection patterns
• Distributor ignition systems or multi-coil systems
Trigger Types:
• Hall Effect
• Optical
• Inductive Magnetic Reluctor
Trigger Patterns:
• Single Pulse per cylinder
• Multi-tooth
• Bosch Motronic
• Ford
• GM
• Honda
• Mazda
• Mitsubishi
• Nissan Optical
• Subaru
• Toyota
• Volkswagen
Features:
• Windows 2000, XP, Vista compatible software
• Real time programming, instant hesitation free adjustment while engine is running
• Fully user definable 16 x 16 mapping
• Tuning via Volumetric Efficiency (VE), Injection time
• Selectable onboard internal MAP sensor rated to 150kPa (up to 1.5 Bar or 22psi boost)
• USB and CAN Communication Port
• Custom sensor calibaration allows for most factory sensors to be used
• 2 x User programmable outputs
ECU Fixed Outputs:
• 4 x Fuel Injector outputs (for high impedance injectors only (ie: above 8Ω)
• 4 x Ignition outputs
• Tacho
• Thermo Fan
• Fuel Pump
ECU Programmable Outputs:
• 2 x Programmable Outputs
ECU Inputs:
• Air Temperature
• Aux Rev Limiter
• Coolant Temperature
• Manifold Absoloute Pressure
• Roadspeed
• Throttle Position
• O2 Sensor (Narrowband or Wideband)
Functions:
• CAN Communication
• O2 Control
• Over Boost
• Gear Setup
• Decel Cut
• Transient Throttle Enhance
• Rev Limiter
Correction Tables: Fuel / Ignition:
• Air Temp Correction
• Barometric Correction
• Coolant Temperature Correction
• Injector Dead Time
• Map Correction
• Post Start
• Prime Pulse
• Wide Open Throttle
• Zero Throttle
Interested please contact us @ [email protected]
We are located in Bandar Sunway beside Sunway College.Behind Works Engineering.
012-2206117 (Denny)
016-9973300 (MATT)
Check out our D`s Garage sales item.
Find us in Facebook D`s Garage.
:wavey:
---------- Post added at 05:11 PM ---------- 6 hour anti-bump limit - Previous post was at 02:51 PM ----------
:wavey:
---------- Post added at 09:19 PM ---------- 6 hour anti-bump limit - Previous post was at 05:11 PM ----------
:wavey:
BumpBump
---------- Post added at 03:31 PM ---------- 6 hour anti-bump limit - Previous post was at 10:46 AM ----------
:wavey:
---------- Post added at 07:36 PM ---------- 6 hour anti-bump limit - Previous post was at 03:31 PM ----------
:wavey:
:wavey:
---------- Post added at 09:27 PM ---------- 6 hour anti-bump limit - Previous post was at 05:49 PM ----------
:wavey:
:wavey:
---------- Post added at 02:47 PM ---------- 6 hour anti-bump limit - Previous post was at 10:19 AM ----------
:wavey:
---------- Post added at 07:23 PM ---------- 6 hour anti-bump limit - Previous post was at 02:47 PM ----------
:wavey:
:wavey:
---------- Post added at 03:05 PM ---------- 6 hour anti-bump limit - Previous post was at 12:31 PM ----------
:wavey:
:listen:
---------- Post added at 02:11 PM ---------- 6 hour anti-bump limit - Previous post was at 10:17 AM ----------
:wavey:
---------- Post added at 05:15 PM ---------- 6 hour anti-bump limit - Previous post was at 02:11 PM ----------
:wavey:
---------- Post added at 06:47 PM ---------- 6 hour anti-bump limit - Previous post was at 05:15 PM ----------
:wavey:
:wavey:
---------- Post added at 05:56 PM ---------- 6 hour anti-bump limit - Previous post was at 12:18 PM ----------
:wavey:
---------- Post added at 08:38 PM ---------- 6 hour anti-bump limit - Previous post was at 05:56 PM ----------
bump bump
:wavey:
---------- Post added at 06:24 PM ---------- 6 hour anti-bump limit - Previous post was at 12:52 PM ----------
:wavey:
:wavey:
---------- Post added at 05:21 PM ---------- 6 hour anti-bump limit - Previous post was at 01:48 PM ----------
:wavey:
---------- Post added at 08:11 PM ---------- 6 hour anti-bump limit - Previous post was at 05:21 PM ----------
:listen:
:wavey:
---------- Post added at 03:02 PM ---------- 6 hour anti-bump limit - Previous post was at 11:30 AM ----------
:wavey:
:rofl:
---------- Post added at 02:27 PM ---------- 6 hour anti-bump limit - Previous post was at 11:02 AM ----------
:wavey:
---------- Post added at 02:28 PM ---------- 6 hour anti-bump limit - Previous post was at 02:27 PM ----------
:wavey:
---------- Post added at 06:40 PM ---------- 6 hour anti-bump limit - Previous post was at 02:28 PM ----------
:wavey:
---------- Post added at 10:12 PM ---------- 6 hour anti-bump limit - Previous post was at 06:40 PM ----------
:smokin:
