Halfcut 20v S/T
hans
Guys, is it worth buying the halfcut at RM2.2k? Everything complete except bumper&grill. I'm going to buy it on monday. Need the advice.
Already bought the half-cut. AE101 body. Price 2.5K (Expensive) Comes with FX bumper &grill,Rear disc,Inj pump.
Let me know anybody got side skirt for AE101.
2.2k for wat halfcut...now the average price for a halfcut...also lowest i heard 3k...if so cheap then better u check the engine...ask from an experienced mechanic...so check for you...start the engine hear the sound...the mechanic knows wat to do...then only u buy...hope this helps...
I't a AE101 halfcut with a 20v silvertop. Already start the engine it sounds good. ok ka the price. is it worth buying.
You need to check whether it come with rear diskbreak and the fuel tank as well or not.
if yes, 2.2K is a normal price.
currently, silvertop half cut (manual) range between 1.8K - 2.2k depand on the condition and negotiation of the price.
Last time (7 month ago) I purchased AE101 20V silvertop half cut at RM2400. Expensive?
But it do come with following items:
1. JIC hi/lo soft/hard adjustable coilsover(Complete)
2. JASMA FGK 4-2-1 extractor
3. TRD spark plug cable.
3. Cusco strut bar.
4. Cusco break stopper.
5. and of coz together with rear disk break and fuel tank and a few more extra after market gadget.
EG9.
The price he given me is without rear tank & rear disc. Is it a must to have the rear tank as well?
Hi hans,
rear disk it's must for your own safety...well 4 fueltank.if yr car using efi i think u can use back yr fuel tank.....
if like that its quite expensize bro.....should be more cheaper it without those item......
try and look another shop....there is alots of svt out there......and there is still alots of out there is more cheaper brother...
my 2 cents....... :D
EG9.
Then it's expensive.
I bet that you want to convert to rear disk break as well, because without the rear disbreak, you car will not able to go through puspakom inspection sucessfully.
Rear fuel tank is a must, you original fuel pump won't able to supply enough fuel to 4AGE 20V.
corolla_gt,
I thought so, the price is quite high.
Any shop tahat you know that have the whole package with a lower price?
Need to fix it by tomorrow or tuesday, cause the old engine is already dismantle.
How about cusco coilover for AE92 (RM1,500). Can it fit inti AE101?
where is your location brother....
because im also searching for a bt halfcut for my friends......
maybe i can give a try for you too...
regards,
GT :ph34r:
