Guys,...
Wait wait wait...
If I'm not mistaken, u can't do any modification bcoz there another very signification factor to limit the power...which is the 'crank shaft sensor'...
If u change the top & wiring, i don't think it's work...
instead of wiring, I don't know whether it could be suit or not...
If u change the block together, better convert to Mits' 4G93 engine lantai...I suggest...
Hi Evo.Z
Is there any big different perform the 'MUTII'?
Well my fren was in experince that not really such big diff. after modify the air filter, 2inch piping, adj cam pulley, SAFC & etc...(fuel pressure regulator...maybe; forgot...long time oredi liao)
It's seems like fuel limited for displacement...
And the only way to modify is air filter, piping, adj cam pulley, & a famous brand of crank pulley(forgotten...AEM maybe) with crank sensor (same function also)...but very high cost... to lighten ur REV...
Correct me if I'm wrong...!!!:wavey:
