Greddy Intellegent InforMeter
ftzone
full throttle zone
Anyone interested in this product?
Price RM990.00 nett.
Brand New Greddy / Trust Intellegent Informeter. Interchangeable case color.
For ISO 14230 OBD2 Vehicles Only.
Product info: Designed with a compact plug and play color LCD display, the Informeter allows you to monitor, set warning points and datalog your vehicles performance though it's own OBD sensors. Select through important signals like Speed, Tach, Temps, Air Flow, Voltage, etc. (up to 25 channels), to monitor. The easy to use navigation menu allows you to select between various screens and displays: Digital, Analog or Bar Graph and 2ch, 3ch, or 6ch screens. You can also set warning points and pre-warning points, which will alert you with audible and visual highlights of important readings. Datalog up to 6 channels of data, and replay them. This is great for tuning. In addition to being functional the Informeter is also infinitely fashionable. Seamless changes in backlighting color, GReddy signature wall papers and colored backgrounds, along with a clear bezel to install colored face plates or even custom face plates, offer a endless options to match any vehicles interior. And to aid in mounting the unit can flip the display 180 degrees to free even more options. The GReddy Informeter is a key tool for all; beginners to pro tuners.
http://www.trust-power.com/02greddy/infometer/001.jpghttp://www.trust-power.com/item/1010.GIFhttp://www.trust-power.com/02greddy/infometer/002.jpg
http://www.trust-power.com/02greddy/infometer/003.jpghttp://www.trust-power.com/item/1010.GIFhttp://www.trust-power.com/02greddy/infometer/004.jpghttp://www.trust-power.com/item/1010.GIF
http://www.trust-power.com/02greddy/infometer/005.jpghttp://www.trust-power.com/item/1010.GIFhttp://www.trust-power.com/02greddy/infometer/006.jpghttp://www.trust-power.com/item/1010.GIF
http://www.trust-power.com/02greddy/infometer/008.jpghttp://www.trust-power.com/item/1010.GIFhttp://www.trust-power.com/02greddy/infometer/009.jpghttp://www.trust-power.com/item/1010.GIFhttp://www.trust-power.com/item/1010.GIF
http://www.trust-power.com/02greddy/infometer/010.jpghttp://www.trust-power.com/item/1010.GIFhttp://www.trust-power.com/02greddy/infometer/011.jpghttp://www.trust-power.com/item/1010.GIF
http://www.trust-power.com/02greddy/infometer/012.jpghttp://www.trust-power.com/item/1010.GIFhttp://www.trust-power.com/02greddy/infometer/013.jpghttp://www.trust-power.com/item/1010.GIF
http://www.trust-power.com/02greddy/infometer/014.jpghttp://www.trust-power.com/item/1010.GIFhttp://www.trust-power.com/02greddy/infometer/015.jpghttp://www.trust-power.com/item/1010.GIF
http://www.trust-power.com/02greddy/infometer/016.jpghttp://www.trust-power.com/item/1010.GIFhttp://www.trust-power.com/02greddy/infometer/017.jpghttp://www.trust-power.com/item/1010.GIF
http://www.trust-power.com/02greddy/infometer/018.jpghttp://www.trust-power.com/item/1010.GIF
This is a Greddy Intelligent Informeter. It Communicates with the factory ECU to read up to 25 Channels Like: Speedometer, RPM, Water Temp, Ignition Timing, Injector Rate, Intake Air Temp, Fuel Temp, Air Flow Voltage, Intake Manifold Press, 02 Sensor Voltage, A/F, Battery Voltage, Throttle Position, WGV, ATF Temp, EGR Temp, Gear Position, 4WD Ratio, Exhaust Temp. This device will work with all OBD II vehicles, but only SOME perimeters will be displayed depending on the vehicle.
Ming_FD3S,
It doesn't come with senders/sensors. This device is plugged into the vehicle OBDII Diagnostic Socket. It uses factory sensors for readings. If you OBDII is not equipped with certain sensors, that reading will not function in the greddy intelligent informeter. It is similar with the APEX'i I-Moni.
Usually vehicles manufactured after year 2002 should be equipped with OBDII
p/s: instead of posting in my threads with separate questions, you may want to PM me instead. :)
hey brother, the price can nego ???
can use for myvi ?? and u just sell item or plus installation ??
dude,
is the installation diff? and i am riding a mitsubishi colt ralliart, please check if it can be used on my ride.
hi mates ..
very interesting on this product...
long itme see it on Taiwan website ..
reasonable price too ?
can i know more details 1st ..
filterz, i no longer selling informeter leh... sorry.. but i can't help.
if you want similar functions you can consider blitz r-vit, apexi i-moni or ark design only.
