Getting a 2nd hand Mazda RX-7 1996
Here is my 2 cents on rotaries. I owned one for many years and moded them and take the advise from me.
1. Most rotaries will last any where from 25,000km to 120,000km. Depending on how its taken care of. At 100,000km the apex seal are quite worn already and it wont take much to break them.
2. If running turbo rotaries, change oil 1500-2500km. Because there is a shit load of fuel dilution to the oil even though it looks clean. With fuel diluted in the oil, it cannot lubricate well under stress and wear the seal. Even at 1000km take the dip stick out and smell the fuel, it'll smell like its been heavily mixed by petrol.
3. Never start and drive a rotary straight away (like we all do in piston cars) when its cold and engine oil is not up to temp. Its easy to break and wear the apex seals. Always allow it to idle to 60C before driving away and drive away GINGERLY shifting at 2500rpm and never drive in boost only at -200 vacume and drive until engine oil reaches 80C then only you can start driving normally and whack the car. Thus its 100% important to install an engine oil temp and boost gauge. You will notice when whacking engine oil will reach 110C very fast thus you need to cruise and cool down. Got money get a big oil cooler.
4. Normal driving in town can use mineral engine oil and on track days you can use fully syn.
5. Spark plugs have to change every 10,000km as they get worn and fouled up. The spark plugs fires 3x more vs regular 4 banger.
6. FC series engine, gets flooded easily and cannot fire up when hot. Like park car then shopping for 20mins then come back cannot fire up. You need to cut power to ecu or fuel pump crank engine for 10 sec and then power up ecu or fuel pump and it will start. Problem gets worse when the engine is old or worn as compression is even lower. Problem as been greatly minimized in the FD series about 99%.
7. Cooling is of maximum importance in rotaries, it will over heat if you don't take care. Don't get the auto version as the auto trans cooler is in the radiator (like all auto cars) and puts extra heat load on the cooling system even more. Thus get a manual or die die disconnect auto trans cooler and use an external oil cooler. More over the auto trans is not strong and cannot handle torture and anything more than 280hp reliably on both FC and FD.
8. If you buy RX7/8 get ready money for spare engine.
9. Basically its takes money, love and care with great amount of discipline to own a rotary.
If not better buy S13 or s15 silvia. Easy 350-400hp and can drive until the cows come home and potong kereta got plenty of spares and tuning shops are filled with all the SR20DET parts. Another option is Supra with 2JZ.
Cheapest fun car will be Cefiro A31 with RB20DET.
RX-7 owner best advice so far :top:
or maybe get a Toyota Soarer 2.5L with 1JZ-GTE. Is a nice and rare car.
Not easy to find one though. Previously was on sale in ZTH. RM79K.
Did you call or sms bro? Try calling. But from what I see on those goodies he is giving, I'm not sure
how true it is. Also S2000 Neo for sale? Really never heard of it before.
Best call to find out.
Yea I called, and within the span of 20 seconds of starting the conversationt the dude just ran of to a meeting. Talk about timing, hahaha.
---------- Post added at 02:31 PM ---------- 6 hour anti-bump limit - Previous post was at 02:25 PM ----------
Good news is that my dad plans on chipping in so the Proton Satria Neo is completely out of the window. He likes quality...
So the budget is probably gonna go up though I'd like to put a max at RM100K.
I really like the Nissan Silvia S15 idea. Found one http://www.carsifu.my/cars/68417/nissan-silvia-2-0-r-type-for-sale-in-others-by-june-yong. What do you guys think?
Though, it would be nice to get a stock car so me and my dad can happily toy around with it.
If any other car suggestions are out there, these are an absolutely must:
1) Manual Transmission
2) Maintainence and moding parts must be decently available
3) RWD
I was also thinking of a Supra, but the car is a bit heavy. Would prefer the Nissan Silvia S15 over that.
Thanks so much guys, this community rocks!
---------- Post added at 02:34 PM ---------- 6 hour anti-bump limit - Previous post was at 02:31 PM ----------
Your two cents!? Dude you sound like a rotary GOD :rofl:
Seriously appreaciate the time you took to lay this out for me. I knew a rotary was troublesome but wow..... that's really troublesome, hahaha
---------- Post added at 02:38 PM ---------- 6 hour anti-bump limit - Previous post was at 02:34 PM ----------
Anyone seen any other Nissan Silvia S15's out there for sale?
holy crap.... how could i forget about the silvia??? hahahahhahaha :banghead::banghead::banghead:
for FR platform...this is definitely the top choice.....when it comes to power AND reliability... its pretty hard to beat nissans... mod options are in abundance... even more if ur willing to order overseas....
since ur budget very the cun now... S15 is definitely THE choice... if i was considering a RWD setup... this is definitely my top choice too..
though id also be itching for an MR-S with a K-Swap :thefinger:
3) RWD
S15 and Supra can't really be compared with. But then if there is a budget, I would take S15 too. Performance wise, 3.0L Supra is indeed a monster if one can afford to turn it to one.
Still love the design of the Supra :biggrin:
Anyway, once decided then just stick to the one u decided. Getting too many suggestions, u will end up in a dilemma. :biggrin:
Personally try to find a stock s15. Better don't but a moded one if can. Then add ecu, boost controller, full exhaust and air filter to get 320-350hp which is also limit of the stock clutch. Just nice for street and everyday drive and reliable. When you want 400hp and over that is where big bucks start and not street friendly to drive. But good for drift and track.
U can get a descent Silvia S15 with descent mods for about RM85-90k.....my neighbor managed to get a Supra for slightly under RM60k, but its an auto. And he also has a S15 which he is looking to let go. Might have seen it in mudah, the matte orange one.
I own a S15 for the past 7 years so i am speaking from experience, its an affordable 2 door, RWD daily driven to work and for weekend Gymkhana events car.
Mine is a NA but is in the midst of going down the turbo lane. Just to give you an idea on what the maintenance cost is like.....my usual service cost me about RM270, runs on timing chain so dont have to bother about changing timing belt (but it is advisable to change at around 100k km), parts are interchangeable with the other S chassis family (180sx, S13,S14) but mind you not everything as handling parts are only shared among the earlier S Chassis models and the A31 cefiro and certain skyline models (forgot which one).
Second hand and after market parts are everywhere and there are a lot of mechanics that can handle a SR20 (unlike the rotary where you REALLY NEED a specialist to handle your ride)
Just my 20 cents.....
---------- Post added at 09:45 AM ---------- 6 hour anti-bump limit - Previous post was at 09:44 AM ----------
The 180sx and S13 is about RM40-60k and the S14 is about RM60-75k
---------- Post added at 09:47 AM ---------- 6 hour anti-bump limit - Previous post was at 09:45 AM ----------
i use in daily to work and drive an average of 45km a day to work with the silvia and for 5 working day i use an average of half a tank of fuel (RM50 for Ron95 at RM1.90)
Awesome share bro. NA S15 would be the Spec S correct? I'm a sucker for the S15 body lines, definitely one of the best looking coupe out there.
I considered a S15 Spec S once, but went to get a Honda instead. :biggrin:
Rotary engines requires a lot of maintenance. Even a Nissan 350Z owner told me a FC3S consumes more petrol than the 3.5 litre 350Z. Maintenance is more expensive than 350Z as well.
If you want to find Silvia, there are cheap ones like S14 or S13 but they are quite rare compared to S15. Don't forget, there is still the RPS13 180SX as an alternative for Silvia. That is almost the same with Silvia except for different external looks.
Looked around for a decent Silvia, though not sure if I can maintain it. Let alone pay the petrol of a 2.0 litre...\
I'm refocusing my attention to the Satria Neo. Though i'm hunting for something like this http://www.mudah.my/Satria+neo+S2000+FLOAN+1+6+R3+with+full+BODYKIT-23170724.htm
Unfortunately the guy isn't responding...
this one iklan only.. where got neo S2000 on sale.. :thefinger:
maybe the yellow colour scheme only like neo S2000
its the 2013 Satria NEO CPS R3.. ad all misleading..
CPS engine only.. where got 145hp.. only real R3 Neo has 145hp..
summore can drift?? :thefinger:
iklan pun mau menipu kaw2.. :rofl:
call the salesman say u want the s2000, by hook or by crook u want it...c wat he says....:rofl:
suddenly this suspicious guy import the MEM s2000 IRC edition.. he said this car cannot register jpj that's why i dont sell anymore.. hahahahah :rofl:
Haha, somehow I won't be surprised if that's the outcome :rofl:
---------- Post added at 10:30 PM ---------- 6 hour anti-bump limit - Previous post was at 08:54 PM ----------
I need help hunting down a Nissan Silvia S15 Spec-R
Manual 6-speed transmission
I found one Nissan Silvia 2.0 R Type For Sale in Others by June Yong
Though if I can i'm looking for one that hasn't been modified.
Any help at all will be very appreciated!
Thanks so much in advance.
http://www.mudah.my/Nissan+Silvia+S15+Spec+R+M+-22800340.htm
Man. Try this. Personally seen it before. Clean to the max. Healthy looked and sound.
I saw that ad last time, already find that sales man kinda bullshitting. Yet he is giving off so many free gifts. Smart Tag, GPS and etcs. Sell one Satria really so much commission?
Best case is selling Satria Neo S2000 :biggrin:
Honda S2000 ada lah.
http://www.zerotohundred.com/newforums/cars-for-sale/377853-honda-ap1-s2000-for-sale.html
http://www.carlist.my/used-cars/1230809/honda-s2000.html
