Gearbox
artnet
1,500 RPM
Hi,
i would like to know whether the C160 gearbox using
the same Clutch lining and pressure plate as the C56?
if getting a C160, the gearshift and the cable also need to use
the original one right? will there be any problem to fit on
the EE100?
Thanks.
this one ask alvin better i also not sure ... the clutch plate and cover is the same as 5 speed .. the shifter and shifter cables not same with 5 speed and 6 speed .. but can modify 5 speed one to masuk 6 speed .. the exact thing to modify not sure ...
ok. thanks.
i just wanna know the clutch... tht is more important.
coz scare hard to find the replacement later.
to mod the 5 speed shifter to 6 speed shifter (unless u change the whole shifter from 6 speed in laa) i only know 1 person who can do it ... huahahahahaa ... sifoos yolk and TOMS can advise u who does that laa of coz ... :P
if i really managed to get a C160 but not the shifter...
then i will buy one modded from them.
the twinpot onto macpherson, i've found one who did it.
but not yet meet him up... busy with examination. :(
