Gear ratio speed
Zat Fero
From Facebook
Have you ever wonder, how much your gear ratio SPEED ?
Can it goes up to 260kmph?
Well if you have all the ratios,final drive and your wheelsize diameter. You can calculate manually (using all the formula) or you just can fill in the blank in this awesome website http://www.apexgarage.com/tech/gear_ratios.shtml .
* You can see changes between wheelsize diameter affect your topspeed as well your rev(rpm).
I hope this helps anyone searching for this gear ratio speed calculator .
* Good luck!:wavey:
