Hi guys.
Since I got my satria neo cps on 2010, my engine is acting a bit weird. Here is what happens exactly:
1- I am driving on second gear
2- Releasing the gas pedal
3- When my engine RPM is at 1000 (the car is still moving - 2nd gear), if I press the gas pedal to max, it seems like it doesn't get enough air or too much petrol going in. Then the car won't accelerate.
I have to totally release the pedal, then press it gently.
4- Now I am in 3rd gear, RPM at 2000, when I max press the pedal, it accelerates pretty well.
5- At forth gear, no matter what RPM I am (2000+), when I press the pedal normally or to max, the car won't accelerate.
6- Lets not talk about 5th Gear :D it is the worst!
So after all these years, I realized that I need to push the gas pedal to an exact extend, then only the car moves properly (not hard, not low). If it is a bit off, then it won't accelerate (When I say no acceleration, I mean not even a minimal acceleration, it gives the same feeling as your engine is out of gas and it is about to switch off - so the car jumps a bit).
Any idea what can cause the problem? And how can I fix it? Thanks in advance
-Max
-Max
