gear lever extension for 1JZ
zarathir
i want to find someone who can help me in customizing my manual 1jz gearbox so that it can fit nicely in my mercedes 280se W126. fitting in problem is only on the gear lever, where the gear lever doesnt come out from the old gear lever housing, but instead, it came out inside the dashboard. so, i need an extension. can anybody recommend me a place to do this customization??
if ur using supra 1jz gearbox, maybe u can swap to soarer 1jz gearbox, which extends around 1.5inch further to the back.
if u need it to be even further, then google is ur fren.
http://www.clublexus.com/forums/performance-and-maintenance/183050-solution-to-soarer-r154.html
http://www.supraforums.com/forum/showthread.php?t=413913
http://store.driftmotion.com/static/i-r154shifterextensionformk4sc300.php
google more n u will find more possible solutions to ur problem...
u also can modify the gear lever depends....
or u can directly call my fren
ah hou 012-6671254
he can do the thing u wan cause he also using the 1jz engine
