P params Sep 19, 2012 #1 hi, i just o/hauled my audi gearbox and its been humming at certain speeds. any ideas to the cause. and solutions to simiiar problem faced. thanks:
L LesleyAprotto Banned Sep 20, 2012 #3 Probably your ATF is not sufficient... Or.... You may have used a lower grade of ATF (Automatic Transmission Fluid)
ken yeang 6,000 RPM Senior Member Sep 20, 2012 #4 should take it back to the garage, and tell the mech that your g/b is humming now....
^pomen_GTR^ 7,000 RPM Senior Member Sep 20, 2012 #5 what models? perhaps it was the rear differential?? (if FR layout)
DanzEterna Moderator Moderator Senior Member Sep 20, 2012 #6 gear bearing kong edi bro....tell yr mech to check it again.....
P params Sep 20, 2012 #7 thanks guys, will change the atf to full synthetic first and check if the bearing were replaced .would a thicker gasket be of any help assuming t hat the sump might have been skimmed
