fuel pump relay
hi bro.
i just change mine. to a 2nd original. i think its from B16.. for my H22A prelude.
if im not mistaken, original should be about RM1xx .. and the non-original-china made or cap ayam, should be less than that. i got mine from a mechanic, he sold to me rm60. when i fix it. the car starts right away.
i had 3 fuel relay change. 1st i think the old owner had change, and the relay now spoilt, then i change to the 2nd ones.
if im not mistaken, you can repair the fuel relay, by de-solder and solder it back. i never tried coz i have no time.
it looks like this:
http://www.marklamond.co.uk/tech-honda/pgm-fi/main-relay/relay-collection.jpg
pls surf: http://www.marklamond.co.uk/tech-honda/pgm-fi/main-relay/main-relay.htm
does it means that we can swap relays from other honda cars as well? like for example H series ones will fit into B series?
anyone tried before solder and desolder to see it worksss ??
is this relay under driver side steering wheel ?
just to share; mine (b16a eng) use to get burned like every 3-4 mths once, probably the rewiring process after conversion wasnt done nicely, or simply got killed by my stereo amp. what i did was i had a connection wire on standby in between the fuel pump (below the rear seat) and the fuse box (below steering wheel) in case it got messed up. whenever the relay gave way, i just connect the wire to the fuel pump and fuse box (preferably the door window fuse) to run it. at one time i left it like that for almost a year. 5 sen
and hi encik HARPOON.... jom markingmpv pulak hehehehehe
