Fuel Injector Cleaning & Service
ixeo
4,000 RPM
Where in Klang Valley can I get proper fuel injector cleaning & service? I'm talking about cleaning & service using this
http://www.motorscope.co.uk/images/asnu001.jpg
NOT THIS
brothers accessory shop also have, the last time bought it from there...bout 20-25 i think..
last time my pomen sold it at rm15.
Ooo i tot they were talking bout the 3m injector cleaner hehe sorry...
---------- Post added at 04:22 PM ---------- 6 hour anti-bump limit - Previous post was at 04:22 PM ----------
look for andy REV PERFORMANCE...he also does injector cleaning with reasonable pricing....
Any big difference between....
Pour the injector cleaner into tank
And..
Use the injector cleaning machine ?:confused:
And..
The machine uses extremely high pressure and uses different pulses to force fuel through the injector to clean the injector. You can see clearly which injector is blocked and which one is working well. After the cleaning all your injectors will be shooting fuel with the same pattern and pressure confirming clean injectors.
The cleaner mixes with your fuel to supposedly clean the injectors. Theoratically it's possible but you cannot clean a fully clogged injector. There's no guarantee it'll work as well since you can't actually see it working (or not). There's only one cleaning agent that I've come across that can give you real test results by showing you how it works by using test tubes (Bluechem products). It's pretty convincing but like I said, if you had contaminents such as dirt or dust particles that won't dissolve in the petrol, you need a mechanical cleaning service like the injector cleaning machine.
yup, done this for my BT20V at Trial Tuning SgBesi... probably around 2yr ago...
i can't recall the cost but i think at the time they charged me around RM150...:hmmmm:
i ask them to repeat several time until the injector shooting out the same cleaner volume...:rofl:
i went to gt auto...and did the injector cleaning service.
so the service is ok for a cheaper price than N1.
but.......
you wouldnt know your cc per min.as they dont do it.thats the price i had to pay for being cheap.wahahahha
just to revive this old thread.
last year went to gt auto for a cleaning service, but no flow rate result given,
Now iam looking for a place where can give flow rate result, anybody can help me here?
Gt auto no flow rate, n1 also no flow rate, andt rev performance also no flow rate.
Now where should i go?
So did you find any place with flow rate?
