FS- pioneer HU
ICE -In Car Entertainment
FS- pioneer HU
lang
NEW 2006 PIONEER PREMIER DEH-P880PRS CD PLAYER BRAND NEW STILL FACTORY SEALED!
Hi-Volt (5V) Pre-Outs
DSP
Exclusive PRS High Quality Sound Design
Unprecendented control for the purest sound.
Dual (L/R) 16-Band Graphic EQ for unprecendented control
Auto EQ easily creates a baseline equalization for your vehicle
Auto Time Alignment adjusts for speaker placement and creates exceptional staging and imaging
Burr-Brown DAC's for the purest sound
Built-in Auxiliary Input
The DEH-P880PRS features a new built-in AUX input, which can be easily connected with a wide range of external devices, such as digital audio players. Simply connect a mini-jack cable to the connector on the front of the unit.
Supertuner
Supertuner Supertuner III Digital
24-Station/6-Button (18FM/6AM) Presets
BSM (Best Stations Memory)
Local Station Setting Selectable (4-Step)
CD Player
1-bit D/A Converter 24-bit Burr Brown
CD-R/CD-RW Compatible
AGC (Automatic Gain Control)
Disc Title Memory
Disc List
Track Title List
CD Text CD Text
MP3 Playback Compatibility
Codec Support MP3, WMA, WAV, iTunes AAC
File System ISO9660-1,-2, Romeo, Joliet
Max Directory 8
Max. Folder # 99
Max File # per Disc 999
Multisession Disc Play
Random Play Folder/Disc
Repeat Play File/Folder
MP3 Bit Rate 8~320kbps or VBR
WMA Format WMA v7, 8, 9, 10
WMA Bit Rate 48~384kbps, VBR
AAC Format iTunes AAC
AAC Bit Rate 16~320kbps
File Name 64 bytes
Folder Name 64 bytes
ID3/WMA Tag ID3 v1.0, 1.1, 2.2, 2.3, 2.4; WMA; iTunes AAC
Tag Length 64 bytes
Tag Data Track, Artist, Album, Comment
Tag Display On/Off
List Search File and Folder
IP-Bus System Expandability
IP-Bus System Control
XM Radio Ready Yes
Sirius Radio Ready Yes
iPod Adapter Ready Yes (Full, 3-line)
Multi-CD Control
DVD Control
TV Tuner Control
Display Output
Built-in Auxiliary Input Built-In (Rear)
Optional (IP-Bus) Auxilary Input CD-RB10 or CD-RB20 required
External Unit Control 2
Display Features
Face Type Flap Face
Motorization Auto Slide Motorized
Display Type White Organic EL (OEL)
Dot Matrix OEL Size 160 x 48
Multi-Language English, French, Spanish
Button (Key) Illumination Switchable Blue or White
Audio Features
Built-in Speaker Power MOSFET 50W x 4
Continuous Power Output 22W x 4
Equalizer Dual (L/R) 16-Band Graphic
Equalizer Presets 5
User Equalizer Settings 2
Loudness Yes
DSP
Auto-EQ (With Mic Included)
Auto-Time Alignment
Listening Position Selector
BBE Digital
Electronic Balance/Fader
Source Level Adjuster (SLA)
Crossover Network 3-Way Crossover
High-Pass Crossover (HPF) 50/63/80/100/ 125/160/200Hz, 0/-6/-12dB/Oct.
Subwoofer Crossover (LPF) 50/63/80/100/ 125/160/200Hz, -6/-12/-18dB/Oct
RCA Preouts 3 pair (Front, Rear, Sub/Non-Fading)
Preout Voltage & Impedance Hi-Volt (5V), 100 ohm
General Features
Volume Control Rotary Volume
Operation Mode Rotary Commander
Remote Control 10-Key Card
Oddetall radio tuning
Wired Remote Input
Cellular Mute
Detachable Face Security
Face Case (Included)
http://img231.imageshack.us/img231/6957/dsc00278tm4.jpg
http://img241.imageshack.us/img241/1823/dsc00286qx4.jpg
http://img241.imageshack.us/img241/8199/dsc00287ii8.jpg
http://img241.imageshack.us/img241/5243/dsc00289vg9.jpg
http://img241.imageshack.us/img241/237/dsc00290vy3.jpg
6all, 2 booking,1 payment make,3for sale
call or sms se 0124564708
