Iridium 3 midrange (Rm700 plus shipping in Malaysia only)
Used for 9 month, local set with warranty
ULTIMATE Iridium series midrange speaker Iridium 3 is a 75 mm (3") mid-dome with neodymium magnet and chamber.
Speaker type 75 mm (3") doped fabric with chamber
Power handling capacity 100 W RMS / 160 W max
Impedance 4 ohm
Fs, resonant frequency 280 Hz
Voice coil 75 mm / 3" Aluminium flat wire, 5 mm
X-max +- 0,5 mm
Frequency range 250 - 8000 Hz
Sensitivity 91 dB (1W/1m)
Magnet size 80 mm (3,15")
Outer diameter 120 mm (4,72")
Installation depth 35 mm ( 1,38")
Mounting hole 95 mm (3,74")
http://www.dls.se/english/index.htm
http://i102.photobucket.com/albums/m118/louisbrand/PA040209-1.jpg
Impedance 4 ohm
X-max +- 0,5 mm
