FS: 4A 16V like half cut
SideWaysGrey
Greetings folks.
Im selling off my current engine to make way for another.
Currently its taken out from my car and in the workshop. Everything from engine bay goes including dashboard, tank etc
1. 4AGE 16V engine
-head ported and polished
-full engine weighed & balanced
-TRD exhaust extractor
-aftermarket lightened flywheel
-cam covers changed to SC covers and painted blue with TRD stickers.
-after market cam with gears. (dono the degrees)
-clutch and preasure plate 90% new
2. complete engine & dash wiring
3. gearbox modified for shorter shifting and quick RPM gain (Japs did it) This is the same like WhatThe!!!'s gbox for those who have tried it.
I havent tried the gbox but maybe the 4th and 5th gear has been swapped.
4. ECU retuned by Japs for faster RPM gain and redline
5. Digital meter panel & dashboard not from AE86 but AA63 ! Its different than the tradisional 86 digital dash. looks damn cool. The fuel tank is included for the sensors to work.
6. 86 long shaft
7. 86 rear axle disk brake but no LSD
8. auxilaries like starter, alternator, AC condenser etc
Everything goes as a package like haf cut. Take it all for RM 3800.00 or closest offer. Location in Seremban. I can arrange for engine swap into your car at the same workshop. Also registration can be done. I have all legal documents.
Note: AE86 standard half cut is currently retailed at RM4.5K+ What U wont get is digital meter, racing gbox, retuned ECU.
Give me a ring at 012-6904219
rollakid,
the gear positions are swapped not ratios. Means when you engage the normal 4th gear position the 5th gear is in place and vice versa. I got this box from a track car. Its faster and convenient to shift from 5th gear to third. In track it makes a difference.
masterpuppet7
I have another aftermarket 86 exhaust header. better flow then std exhaust manifold
Its even thermal wrapped. PM me if interested.
