From Carb To Injection..
alie
can anyone explain how to change form carb to injection. what need to mod and change. i want to restore my engine. Ford Escort Engine..
dont tell me to change the engine..hhaha...
If the same engine model is available with an EFI version, just change the engine head including fuel rail, TB and injectors, add the wiring + ECU, hook up the necessary airflow sensors and AFR sensors and modify the fuel lines to have a fuel pump and a fuel return line from the fuel pressure regulator.
If that's not available, then you'll have to customize some stuff.. starting with the intake manifold. I've seen an old Jag or Volvo's carb engine being converted to EFI. The workshop used a standalone Haltech E6K as the ECU. They cut and welded the stock carb manifold to convert it to EFI.. it's a twin carb manifold, and it's converted to twin throttles with a 550cc fuel injector at each throttle. In effect, it's still almost like a caburetted car, with the fuel being jetted past the throttle opening rather than being jetted for individual cylinders.
They'll have to add a form of air metering and AFR sensing also. Being a programmable standalone ECU, they could actually mix and match to suit their needs.. can use a wideband sensor at the exhaust pipe for AFR sensing, and they can even plonk in Proton or Nissan airflow sensor, it doesn't matter. The Haltech ECU can be configured to read the inputs of so many different types of sensors, and control so many different types of injectors.
intake manifold,fuel injector,fuel rail, ecu...etc all u hv to change bro....
if u can get the parts from ford escort efi engine then wil be great....
