ZamS Known Member Senior Member May 11, 2005 #1 Dear Friends, Need some info regarding Force Induction (turbocharger / supercharger) for 4G92 MIVEC. Advantage/disavantage?:rolleyes:
H HP Gila Junior Member Senior Member May 13, 2005 #2 ZamS said: Dear Friends, Need some info regarding Force Induction (turbocharger / supercharger) for 4G92 MIVEC. Advantage/disavantage?:rolleyes: Click to expand... The modifications are required as below for maximum boost pressure of 0.6kg/cm. Reduce piston compression ratio to 9.0 - 9.5 which to allow no spark timing delayed. Fit Boost-Cut Eliminator to allow original NA. ECU to operate normally when it sees turbo boost. Supply more fueling for correct air-fuel mix. till 0.6kg/cm turbo pressure. Fit large enough intercooler for better performance & durability Fit VTEC [Valves timing engagement control] Controller to activate MIVEC when boost in at lower rpm.
P psyk Known Member Senior Member May 13, 2005 #3 your nick.. handphone gila ker.. hewlettpackard gila? hamsap gila? :D
H HP Gila Junior Member Senior Member May 13, 2005 #4 psyk said: your nick.. handphone gila ker.. hewlettpackard gila? hamsap gila? :D Click to expand... A gila for the engine hp only.
deacon Senior master debater Senior Member May 13, 2005 #5 or get a developed sc for mivec engine like Jackson racing has for the b16a engine for honda hehehe
