Focal KRX-2 component speakers
ICE -In Car Entertainment
szmy
Item(s):Focal K2Power 165KRX2
Package includes:
Used In BOX
Price: RM 2xxx
(Brand New RRP: USD 1299.99 http://www.crutchfield.com/S-xr3QuICI2Nq/p_091165KRX2/Focal-K2-Power-165KRX2.html)
Dealing method: COD
Location of seller: KL
Contact method/details: Call/Whatsapp/SMS- 017-3270723
Item(s) conditions: Item is used but in excellent 100% working condition
Item(s) features:
-component speaker system includes two 6-3/4" woofers, 2 tweeters, 2 external crossovers, and 2 woofer grilles
-K2 composite woofer cone (Aramid, foam, and glass fiber)
-butyl rubber surround
-2" woven Aramid fiber inverted-dome tweeter
-2-way external crossover with 3 tweeter levels, 2 tweeter slopes, and 2 midrange level settings
-2-ohm impedance
-power range: 6-100 watts RMS (200 watts peak power)
-frequency response: 70-20,000 Hz
-sensitivity: 93 dB @ 2.83 V
-mounting depth: 3-1/16"
Item(s) description:
The K2 Power 165KRX2 6-3/4" component speaker system bears the hallmarks of Focal's "Power Hi-Fi" philosophy. Nimble woofers made from Aramid and glass fibers demonstrate the control needed to reproduce delicate classical passages, yet they'll handle the power needed to drive your bass-heavy music with authority. The sturdy zinc-aluminum alloy baskets are non-magnetic so they won't interfere with the speaker's own electronics. And this 2-ohm system extracts maximum power from your stereo or amp so you'll get a little more punch from your system.
Focal's 2" inverted dome tweeters act like little woofers, dispersing the highs in a wide pattern to create an exceptionally natural soundstage. K2 Power crossovers use hand-made components developed by Focal to deliver an ideal blend of the highs and lows for a dynamic stereo image. The 165KRX2's crossover features three levels of tweeter control, a tweeter "slope softening" selector, and two levels of midrange control so you can dial in the sound to your car's environment.
Important Note: These Focal K2 Power speakers use a low impedance design to pull more power safely from your car stereo or amplifier. This design is compatible with virtually all factory and aftermarket stereos. Focal describes this model as a 6-1/2" speaker. Most manufacturers designate this same frame size as a 6-3/4" speaker. For simplicity's sake we list it as a 6-3/4" speaker.
Picture:
Reason for sale: Pencen ICE
