Flashlights - LED LENSER P5
For further info:
Call +6 012 227 8324
Ready Stock Available
The LED LENSER® P5 is small, lightweight, an energy-saving marvel and at the same time a giant of brightness. It is operated with only one Mignon (AA) battery. Each nanosecond, the built-in DC/DC converter pumps energy through the high-performance LED (Cree, 3 watt). The result is quite impressive and exceeds the light output of (conventional) electric torches that weigh more than ten times as much.** The focussing system (Advanced Focus System) is as convincing as the one-hand operation mechanism (Speed Focus).
* Average values. May vary +/- 15% depending on type of chip and batteries.
Cloverleaf Multi-Reflector System,
One-hand speed-focus.
24-ct gold contacts
High intensity LED; white beam
1.01watts / 59lumens
Up 305 ft effective range
Lightweight tactical aluminum casing black
Rear on/off switch
1 (AA) fresh battery
Up to 8 hours battery life
4.7 inch length
1.0 inch head diameter
Comes with gift box, duty belt sheath & lanyard included
