FF Drifting....
kenzo
6,000 RPM
Hey there guyz, i was talking with ariff yesterday at the OTS 9 about the FF drifting thingy. I met couple of guyz who drift FF cars, so before we have this FF drifting session or something started, im just curious about how many are them who's willing to join? Please do write down your name and number so that i could contact you guyz...Thanks!
-Kenzo-
Wahh...no1 wanna join ar???....like dat Mr. William wont approve lor....plz go give some feedbacks and comments, teamwork do appreciate....thanks!
Yea i know, that's the reason....we need more attention, i've grab some guyz to join but seems that they nvr reply the post....if everybody would had post their names in, at least we could know each other better....just 2 my sense
can kancil drift?i had tried to corner till i need to turn the stereng to opposite direction of the corner...is that consider drift?
kancil ar...lebih kurang lar can lar....see the angle of the front hood is facing....if it's facing the corner means it's a very good angle already....i dun really drift on car park areas....i drift somewhere got alot of corners and quite tight....then it's more advan...but train dulu lar...so i mostly face the corner's.....that's drift...Correct me if im wrong...thanks!
PS: howiechoo....PM ur number and where u stay...thanks!!
i like to play with the corner at traffic light...the directly turn left 1..no need to wait for traffic light..
quite tight corner..around 80 will need to counter the steer and maybe will over a lot...
once try to u turn at the center road divider on a heavy rained day, spin kau kau.....end up my passenger side below there kemek cos hit the divider on the other side road....lolz..till now haven repair...
lol....man, remember!!....it's not necesarry to speed to able to drift, 50-70kmph is driftable aledi lar...i mean, learn slow first....then try faster and faster...till u know where's the limit....i drift around 70-80 when making long corners....and drum brakes are good for FF drift cars becoz it can really lock ur tyres...first learn to lock ur tyres....then drift and pull e-brake till u get the angle....then only later on try the same thing but step the throttle...keep the throttle on the torque RPM so ur engine can pull the car easily...
normally i dun wan to use ebrake..i scare...i had lose control on ebrake b4..nearly cause a major accident..so now dun try ebrake...i just use high speed to and then brake a bit when corner to make my tail lighter and throw my tail out. then just counter the steering...
my ebrake not really will lock my wheel, maybe brake pad kong...do u think brake pad will kong after u overheat it? like going down from genting
well, im not sure about that....but kancil uses drum brake isnt it??...im sure can lock wan...just to workshop and adjust lar...very cheap only wat...trust me u wont learn like that, doin something like that isnt really drifting in a way, i dun think u get much angle and im sure u need more speed for that, try using the e-brake but do it slow...everytime pull kao kao until the car stop....then u jalan....so u can practise ur steering angle and counter it...
wa you two write till so long for wat? haha! l busy drifting my stylus left to right.. haha!
using ppc to read your topics haha!
anyway Sifu Stanley will show you Super Kancil! haha...
Kenso, you wun believe if I tell you I played once at 130-140 at Subang daytona Corner.. haha... balls oso shrink..
Car totally 90 degrees to the Corner till leisit... haha my fren almost thought he was dead... haha! on the way back from ots
oik!
why my name mentioned here wan!? :D :D
wenshen wanna die ah?! :D
hhahahaha LOL
SLK retired liaw la.
but i think got pics somewhere... hehehe
watch and weep!
hahaahhhhaahaha *chokes and die*
LOL (laugh from the grave) :D
http://img.photobucket.com/albums/v711/ninjaiga82/stanleyOTS4a.jpg
http://img.photobucket.com/albums/v711/ninjaiga82/stanleyOTS4.jpg
haha...130-140 is ok....i still remember the same u-turn after the subang parade....it was dem on....the car were like sliding lar....but still got abit angle...wei guyz...when wanna have TT???
btw, my car is 660 auto..haha
dunno can have enuff torque to make the wheel do some spinning on wheel when cornering..
ninja : did u use ebrake?
btw, ijust bought a alarm system also ninja brand...lolz
