F-CON SZ vs UNICHIP
andyc
Hi i would like to know 'the difference in performence between the F-CON SZ & UNICHIP. I need to control timing, fuel and speed delimiter. which one has better control over these categories? i definitely know about the price difference but need to know difference in performance. thanks
One of important criteria to look at is the detail of resolution map. The higher the resolution the better the chip in terms of being able to control the fuel and ignition parameters.
Unichip comes with 12X17 (load vs. rpm) points while F-CON S with 16X24. Based on this F-CON S offers better control as it has more mapping points and that is reflected in the price (about RM4900???). Not sure about the HP though <_< .
I see. Thanks for the insight. F-Con is considerably more expensive when you compare it to the unichip. hehehe That price you quoted didnt even include tuning. hhehee..
Is the resolution of the fuel mapping the only difference between the F-con and Unichip?
thanks
Andrew
Some additional features I could dig up:
UNICHIP:
Boost control
Additional injectors (up to 4)
Water injection
Speed delimiter
F-CON SV:
Fuel cut
Speed delimiter
Additional injectors (up to 2)
I say go for the Apexi power fc. There are tuners who know what they are doing with it. I cant say the same for the HKS sz and the unichip. Remember your car is only as good as its tuning... no matter what huge turbo you have.
