Extractors and exhaust systems
sexycar
4,000 RPM
hello..
how much to custom make a 1982 corolla GL KE70 extractor
for the original 4K engine? I want a tuned length one.. it's
rear wheel drive by the way.
Hi,
We'd like to do you a custom tuned length extractor for your 4K, but at the moment we don't have the right sub-contractor to bend the pipes. However, if you can get a shop to do it, we'd be glad to supply you the specs, FOC.
EXTRACTORS
Why do we need extractors on our car engines?
The original factory-fitted exhaust manifold on your car engine allows a significant quantity of exhaust gas to remain inside each cylinder, where it will mix with the incoming fresh air-fuel charge.
When this happens, less air-fuel mixture can fill the cylinder during the intake stroke. Whatever air-fuel mixture that goes in is weakened by the remaining exhaust gas. Less air-fuel mixture due to the lower intake efficiency, and on top of that, a contaminated mixture means that the power output is markedly reduced in each power stroke. Hence, the factory fitted manifold not only reduces engine efficiency, but also limits the fuel economy of the engine by forcing the engine to work harder in order to produce the required power to propel the car.
The remaining exhaust gas also contributes to a higher engine operating temperature, thereby promoting "pinging" or pre-ignition (especially when the ignition timing is more advanced) and shortening the spark plug's life.
Another side effect of a factory-fitted manifold is that when one cylinder is on the exhaust stroke, exhaust gas pressure is exerted on the exhaust port of another cylinder. For example, it has been tested and proven that in a 4-cylinder engine when number one cylinder is expelling exhaust gas, the side effect is that the exhaust gas also produces a strong pressure at the number four cylinder's exhaust port due to reverse flow.
http://www.powerzone.com.my/images/extractor.jpg
A well designed tuned length 4-2-1 extractor can siphon out the exhaust gas.
This means that when number four cylinder fires and goes into the exhaust stroke, its outgoing exhaust gas has to fight with the prevailing strong pressure from cylinder number one. The piston now has to act as a pump to push out the exhaust gas resulting pumping losses.
How can an extractor improve engine efficiency?
An extractor is not an ordinary piece of exhaust piping. It has to be designed based on engineering formula and produced with accuracy and details to function effectively. The design of an extractor plays an important role in determining the engine's efficiency.
Not all extractors are the same in terms of design as well as functional effectiveness. A badly designed extractor can actually reduce the power output and torque, making the car lacking in acceleration and throttle response as well as increasing fuel consumption.
To ensure effectiveness, PowerZone extractors are designed based on engineering formula. Each and every pipe is calculated for optimum length and size to produce a siphoning effect. When one cylinder is blowing out exhaust gases it produces a vacuum or siphoning effect in the exhaust port of another complementary cylinder. For example, when cylinder one is on the exhaust stroke a siphoning effect is produced in the exhaust port of cylinder four in a four-cylinder engine.
When there is siphoning effect, the piston now no longer needs to pump the exhaust gas out. Thus, the power previously used for the pumping effort is now recovered to propel the car. Furthermore, the cylinder is cleaned of all exhaust gases and hence the incoming air-fuel mixture is now purer and produces more power. Therefore, not only is there a recovery of lost power (pumping losses) but there is actually additional power from the same amount of fuel and air that goes into the engine cylinders.
http://www.powerzone.com.my/images/PZextractorthumb.jpg
PowerZone extractors are designed by using formula to get the right pipe sizes and lengths.
Another important factor that has been taken into consideration is the internal surface finish of the pipes and flanges. A smooth polished finish ensures no restriction to airflow. Other factors include bending angles, jointing, and fitting accuracy. At PowerZone all such factors are duly complied with to give maximum performance standards.
Not only can PowerZone extractors improve your engine's performance, they are also designed for maximum torque and power at lower useable engine rpm.
Next time you pick out an extractor make sure that you ask for an explanation on its design. If you cannot get a reasonable answer, be extra careful in choosing the right one. We, at PowerZone, are ever willing to provide sound explanation and detailed discussion on the design and function of extractors, and most of all, a revealing demo on what type of extractors can actually perform.
© Copyright 2005 All Rights Reserved by NS Performance Tuning Sdn Bhd.
hi..
thanks for your kind offer, would definitely love to have your specs
for my extractor. But all the while, who does all your customer's
custom extractor's fabrication & bendings?
We have them specially made by our sub-contractor using our own designs, but there's a certain volume committment. So, for one off it's not possible.
oic... so for my 1.3 carb engine... what kinda setup & design would u suggest?
I drive my car everyday in the region of 2000 to 4500 rpm... still on stock
1982 exhaust system till today.. would like to change the whole exhaust
system so seeking your advice on sizing & setup... thanks a lot for feedbacks,
much appreciate it.
For Kelisa/Kenari PZ extractor...
heard it has limited stock.
so whats the setting like?...3-2-1...what different with 3-1(hotbits)...
stainless steel???...chrome color?...
can use back the heatshield?....where does the O2 sensor located?...
whats is the length for the pipes?..
i think i can help out here...
its a never seen b4 (or I havent seen at least :P) 3-2-1 design for the kelisa extractor...it doesnt come with the mounts for the heatshield...they (powerzone) does have heat wrap available if you're interested though...
the o2 is located faaaaaaaar below where the 3 pipes converge...wire has to be extended.
no need extend la
i'm using back the ori wire
hmm...my extractor now already mess up my exhaust system
so noisy and don feel power gain
wanna stick back to stock exhaust liao :(
The Powerzone extractor for Kelisa is a 3-2+1 design known as a tri-y.
The O2 sensor wire has to be extended.
et5828: We don't know why yours is not, as you said it's ori. Is it Powerzone extractor that you have? If so, please come in we'd like to see why your exhaust is not performing. After the extractor what piping and silencer do you have?
Originally posted by InitialD@Feb 15 2005, 11:15
Would I need a new downpipe? Does the RM450 include the downpipe?
No, does not need downpipe as the PZ header is a tuned-lengthed primary all the way to the collector, then bullet, proceeding to the piping. No other additional costs here.
I'm not a PZ employee, just in case you are wondering! :lol:
