External fuel regulator ~
Wilson13B
I wanna install a external fuel regulator as i will upgrade the new fuel pump to a high pressure one and will run high boost off it ~
Any problem on Kenari body if install the Fuel Regulator,cause some say it had a returnless fuel system....if so how to install it on that system?
Thanks =)
u got to disable the oem regulator..
for kenari/kelisa 1st gen i dunno..
but for 2nd gen is like this..
1.the oem locate at the entrace of fuel rail(got adapter there).
2.u got to bore a hole on the left of fuel rail and make a nipple there(return nipple for ur fuel rail because of returnless system)
2.kenari tank dont have extra fuel line,so u got to disable the charcoal canistor line to make a return line..i think this thing mechanic tau kot..
then u can install adj.fuel regulator
