Acoustic,
If I am not wrong, exhaust lengths are tune as resonators. Their length matches exhaust timing and using reflected negative sound waves helps draws exhaust gases out. Since the length is constant therefore it can only be optimised for a relatively fixed rpm range. Of course, the pipe size and gas temperature will also determine the velocity of evacuation.
If you agree with me, from your calculation, can we half the primary length since by doing that we are making the primary to resonate at an octave higher using its harmonics instead of the root frequency to do the work? Wonder if it is effective. By making the primary half could actually safe manufacturing time and costs.
Just a thot. Hope that this does not sound stupid.
