exhaust too hot!!
tks84
sifu, just to ask as i am driving a honde integra DA7 1.6..my problem is after driving for half an hour,under the car will get very hot till i can feel inside(such as touching the gear knob,everything on the floor in the middle) try replacing the exhaust still the same..currently 2 inch all the way..when stop get down to touch the exhaust tip, can cook eggs on top liow...my questions is that normal for exhaust to get very hot?or is it other thing?thanks!
normally will got a layer of metal(come originally) above ur exhaust piping mounted to car's body to insulate heat from transferring directly into ur car... check it is there or not..... u might wanna check ur a/f ratio too coz too lean result in high exhaust temp too
piping 2 inch,change the cataylic converter,bullet,exhaust box somemore wrap with thermal cloth and metal plate as well...
but the problem still the same...anyone experience this before?
how to check a/f ratio as mine can't be tune or dyno...
engine D16a(1.6cc)auto..
dats not normal sir, please check the engine temp. if dats normal, den check ur plugs, make sure u rnt leaning out. any pinging sound occuring, especially in the noon? have u strip out any layer of heat insulation material lately (doesnt seem like it since even ur gear knob is hot)? have u make sure dat the gear shifter linkages arent touching the zorst (they run side by side fyi)? what did u do prior to dis sir? dis last info wud be the biggest help if u can provide it, tq sir
