Exhaust smell petrol
bikerz
hi, my gt-t (auto) is stock, only i mod the exhaust backbox to be straight flow. now it smells petrol. do i need to remap my ecu, or something wrong with my car?
When you change the exhaust, your car will run slightly richer but not to the point where you can smell the petrol while driving. Backbox means what exactly? I'm assuming you've removed the cat converter and gone for the usual 3" exhaust.
no, still stock pipe. but the backbox, or muffler, JFA has cut it and make it straight flow in there.
let say it's o2 sensor fail, if i want to test, need another o2 sensor is it?
or do you really think need a remap? it's only a change on the backbox
Short answer - no.
Heaps of Skylines with aftermarket exhausts running no ECU whatsoever. Simply changing your exhaust in the first place causes the car to run rich.
O2 sensor if fails then most obvious would be change in fuel consumption.
According to my mechanic, my O2 sensor gone already. You cn check this by doing a voltage reading (that's what he says la). Basically, a failed O2 sensor will give erratic reading.
Also, my exhaust does smell like the RM2.30/l petrol. Fuel consumption on Shell 97 is ~ 350km per full tank. I was told that this is on the high side for a standard (air filter & exhaust changes only) RB25.
Whatever it is, you shouldn't be smelling petrol during normal driving or anytime inside the cabin. Standing behind the car is a different thing.
Since changing your exhaust, have you seen any changes in fuel consumption? When coming on boost, look in you rear view mirror - is there a lot of black smoke/more than usual? Is your rear bumper a lot blacker than before? Check your spark plugs - are they fouled?
If the car is running rich just because of the exhaust then I wouldn't worry about it. Once you change your blow-off valve even worse. But generally RBs tend to run rich with these basic mods minus any form of ECU or management - this is what I've noticed over the years having gone through all the RBs except the 30.
But if its something else such as the 02 sensor then it definitely wasn't caused by the new exhaust. Probably coincidental or has been faulty only now you've realized. But again, fuel consumption is easiest benchmark - you should know how many kms per tank and should notice any changes.
"Fuel consumption on Shell 97 is ~ 350km per full tank"
consider yourself lucky BR ... mine is only approximately 300km per full tank ... but the again, what the heck ... u gain some u lose some ... as jack black said "...u aint hardcore unless u live hardcore..." ... or smthing like that
Is this city driving? Or highway? Because my mileage varies ;)
Used to be full tank <200kms on highway but now that I'm older and slower, won't be as bad
Used to be full tank quote]
stop-go daily drive from shah alam to bangsar and smwhere nearby
on highway ... if i cruise say by 120kmph, managed to get approx 400, but if im driving like a sicko, is than 250km ... im also driving like uncle nowadays bro, got nothing to chase anymore
by the way, have u ever listen to audioslave's *im a highway* from their first release? ... awesome song and lyric and u should see their videoclip ... hehehe
1. Do you smell petrol near rear bonnet when the engine is off?
This indicate ur tank floater needs repair.
2. Do u smell petrol atht eh engine bay?
Please check your fuel pipe and hoses. Could be a leak.
3. Bad fuel consumption?
O2 is dead
That is just my opinion and based on my experience. But it could also be other problems.
Mana dtg Chris Cornell punya clan pulak ni
my fuel consumption full tank around 350-400km. i smell petrol when i park the car and walk behind it. so i assume from the exhaust. another symptom is sometime car hesitate to go at 3k rpm. O2, or exhaust?
mr cornell + rage agaist the machine (minus senor zach de la rocha) = SUPERBAND ... hehehe
btw, im a big follower of all those trendsetters; pearl jam/mr vedder forever, the old stone temple pilot before mr wieland went nuts, soundgarden with awesone mr thayil's axing and of course mr cornell's powerful voice, nirvana too bad to them mr cobain decided to go to *heaven* early etc etc etc:biggrin:
opps ... sorry to the threadstarter, im so out of topic ... but then again *firestarter* from that brits electro band is not that bad either
