exhaust setup for gsr
wildboar
guys, wats the recommended exhaust setup for a standard gsr? using the original route or getting a 4wd tank for direct piping thru the center?? will there be any differences in terms of performance?? pros and cons of each setup??
thanx for ur feedback...
of coz 4wd tank is always better.. coz the fuel pump also comes together. have to make sure it's working la.. coz when i transplant my car time.. my 4wd tank fuel pump got problem. If u are driving Wira/Putra 4wd can be optional.. but if satria strongly recommend 4wd tank.. coz installing the exhaust piping would be easier... some of the set-ups I've heard for Std or lightly modified GSR are as below
1. Original Exhaust Manifold
2.5" Pipings and 2.5" Inlet Muffler
2. Original Exhaust Manifold
2.5"Piping - 3"Center Piping - 3" or 3.5" Inlet Muffler
3. Custom Exhaust Manifold ( Can fit External Wastegate )
3" all the way
FYI : I used the first option when I just finished my transplant.. den I upgrade to the second setup. Higher High-End Power. That is for sure.
