Evo 1-3 suspension components on a Putra
whatdamn
like the ttitle of this thread, my question is, what suspension components (lower arm fr/rr...etc) can be directly bolted on to a stock putra?
i'm currently aware of the rear control arm and the rear anti-roll bar being able to bolt-on to the putra.
anything else?
thanks.
EVO anti roll bar can't be used lerz... coz' they're partially bolted onto the 4WD system... unless ur putra drop in 4WD as well. hahaha.. =Þ
Suspensions should be plug and play. Lower arm all should be plug and play as well.
alvin24,
oops, i meant to type ARB from an FTO hahha. my bad. anyway lemme get this straight ya, the fr and rr lower arms fit or just the rr and do i need to get the whole rear/front knuckle,etc to fit the arms or just take it and dump it in?
any idea if the engine mountings from an evo 1-3 would fit putra?
thanks.
Engine mounting I can't remember for SURE... but if not mistaken 2 pieces are the same as an EVO's ones. CAn't rememer which 2 either... think they're the ones at the bottom.
Knuckle not effected by the lower arms. Rear basically just swap the lower arm piece... no problem. Front i don't dare to confirm... but should be also just drop in as well without the need to change other things. Get a mechanic to confirm lerz....
