engine V6 1.6
noler.... not mivec... normal v6 engine.... engine code 6A10....
hp arr??... need to google... or u want other forumer tell u lar...
edited:
engine spec...
Displacement, cc: 1597
Engine model: 6A10
Max.power (Net), kw(PS)/rpm: 140 ps (102.97 kw) / 7000 rpm
Max.torque(Net), N*m(kg*m)/rpm: 15.0 kg*m (147.10 N*m) / 4500 rpm
Power density: 7.71
Engine type: V type 6 cylinder DOHC24 valve
Engine information...
Fuel system: ECI multiple (electrically controlled gasoline injection)
Turbocharger: No
Fuel type: Unleaded premium gasoline
LEV system (Low emission vehicle): No
Compression ratio: 10
Bore, mm: 73
Stroke, mm: 63.6
Fuel consumption at 10-15 modes, l/100km: 8.3
wats ur definition of fast???
if u wan pick up.....
sure cannot la......
mayb top speed still ok lo (provided remove speed cut).....
how much do u expect from a 1.6???
its not a vtec....
not even a mivec....
anyway...
still need a definition of fast la...
0-100 at xxx sec???
top speed at xxx km/h???
coz for me....
0-100 at 8-9sec edi considered good enuf.....
top speed can reach 180km/h edi enuf lo....
how fast u wanna run on a wira chasis???
anythin goes wrong ur car will just wrap u up....
n byebye.....
so what is the best n low maintanance?
which is the best? GSR? MIVEC? or EVO?
tell me bout the engine spec n information of speed..
thank you
if u car is wira chasis, just forget about EVO... JPJ is not approve.
compare between GSR and MIVEC, there is no different in between engine parts as both of them can get the spare parts easily.
Of coz, for the lazy people like me.. mivec is better.
can any one show me a pic of wira sedan that has been make-up..
dude..rather than you wait for someone to upload the pic :bebored: ,juz stand by the roadside n you'll get lots of types of maked up sedan wira's..or juz go to the nearest parking lot,much better view,can look at every angle..n by the way,the 1.6 V6 kind of ok laa..very smooth n quiet..
v6 1.6?? for sure u will regret whn put it in..
the sound grand onli.. but..FC sucks compare to those ori 4g....6 piston man not suitable for town drive...
spare parts also hard to find...
really wanna to put it in your car engine bay...thn good luck to you..
yeap.... vr true.... 6 pistons, more rotating parts, more prone to wear n tear, more power needed to move the piston enertia.... thus, pickup and town drive isnt a vr good engine... but if u planning to use it as a highway cruiser or long distance drive, its a vr nice engine with smooth rev climb.... produce vr nice sound too....
V6 engine got high maintenance compared to other 4G9X series..FC oso high,
bro what type of make-up do u want, install body kit loo or if wanna looklike gsr/evo just convert the body parts..
if u got a lot of money buy and original parts from chop shop, or if wanna saved buy it from accessories (not recommended)..
hehehe think it 1st..
i just got 1.6 wira sedan (year 1998).. i dont know what to do with it.. all thought in still a student.. so i need someone to help me what to do with it?? HELP ME PLEASE.. with a low maintenance.. pm me please..
i've had an experience with one before... i'd say it sounds VERY VERY nice.. but power wise... err ... umm... a gti will be faster
Everythings just remain to stock is the best for low maintenace.:biggrin:
